trunk wont open
trunk wont open
so i was cleaning out my trunk and trying to repair my leak. i saw a switch thing on the trunk lock and i flipped it but didn't flip it back. i closed my trunk and now i cant open it. i tried to use the key lock on the trunk but the lock doesn't work!
ps: its on a sedan
ps: its on a sedan
there is a little slider button on the rear latch that you can slide so the trunk wont open from the inside. if thats not the problem then you should just have to take the latch off, clean it thourghly, and re-grease and you shouldn't have a problem.
unless it is frozen???
You need to get at it first and hes saying hes locked out of the trunk because the key wont open it from the outside either.RJ93SS wrote:there is a little slider button on the rear latch that you can slide so the trunk wont open from the inside. if thats not the problem then you should just have to take the latch off, clean it thourghly, and re-grease and you shouldn't have a problem.
Looks like your going to have to do the crawl of shame through the backseat.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
The little lever you flipped on the latch is called the valet lockout. It's so that when you give the valet parking guy/girl your keys they can't get into your trunk. It disables the trunk release inside the car. (This is in the owners manual.) Also, there is supposed to be a valet key, which does not open the trunk from the outside. I'm not too sure about the valet key though, my 91' SS only has one key and it doesn't open my trunk from the outside. Hope this helps a little bit.
The original valet key only opens the doors and the ignition. That's the only functions a valet needs.
The master key would open the doors, ignition, trunk and glovebox.
If your key doesn't open the trunk (or the glovebox), you might have recieved the valet key with the car. A dealer can most likely make you another master, for a price.
