As a brief forward, I'm going to be swapping my current 4eat to an 02' WRX 5mt that has had the LGT 1-2 gear/mainshaft swapped in. Some of you may recognize this tranny
Tranny crossmember - I am receiving the updated 'H' style tranny crossmember. According to Dscooby this may require slight shimming. I will search on RS25 for this as suggested but wouldn't mind a few starters. I will be buying a new Grp N tranny mount to compliment the new Grp N motor mounts I will be installing.
Rear Diff fitment - I am receiving the proper lsd rear diff to match the 1.1:1 center diff and the corresponding axels. I am also getting a corresponding driveshaft so I should be good on those two fronts. However, are there any changes in how the diff actually mounts to the car?
Starter Hole/Stub - As I currently understand it, the 02' WRX tranny has a hole or stub that needs to be adjusted or is different than the mounts on the EJ22T bell housing. This is an area where I need to do a little more searching and the above mentioned thread likely addresses. I am assuming this is an issue that is pretty apparent/easily fixed?
Clutch choice - This is a big one and probably one of the deadest horses that gets beat on. Since I'm doing a full swap I don't care about differences in WRX vs. SS flywheels. My current plan is to get a new 12-14 lb lightweight WRX flywheel (I will be doing a lot of Auto-X with this car). The real question on the clutch is whether to get a stocker or a Stage 1 clutch. My foremost concern is not breaking my nice new tranny. I'm looking to take the engine power output to the limits of the stock longblock and/or the tranny - my current understanding puts this at around 300 chp. My current thought is to go with a standard Exedy stock replacement and stay away from the pucked clutches. I would prefere to have slip in the clutch and not shatter gears. Having the wider LGT 1-2 should help a little but I'd really prefere to keep the teeth intact. Folklore on Nabisco says the stock clutch and P/P should hold around 290 ft/lb. I guess I don't have a specific question on this one but am instead fishing for opinions/input.
I think that's all I have right now but I'm sure I'll be back here and there through this swap. Any and all comments or input is welcomed as I know a lot of the guys here have walked this road already and a bit more experienced than I am.
Thank you in advance.
