Exhaust
Kam
Exhaust
Post by Kam »
Josh,
You're right about the explanation - ha ha ha!! In the UK we're blessed with a law that says cats are required on all vehicles registered during or after september 1992. I have a 1991 Legacy GT wagon and also a 1990 1.8 GL wagon. The 1.8 never a cat on it from new and the GT I don't know cos it only came into my ownership late last year without any cats. I've since replaced the decatted exhaust on the GT for a much better flowing job made by Mongoose.
I'm making an assumption (albeit a sound one based on my subaru workshop manual) that the manifold (collector?) on your 2.2NA is the same as my 1.8 variant. On my UK car it had a silencer in this part and not a cat. I think the cat will be the one on your mid pipe as you say. I did change the downpipes (it's not really a manifold I suppose) for a custom stainless job at the difference was amazing even on the puny EJ18. Unfortunately, after an incident with a flying truck tyre the place that fixeed my car replaced the downpipes with a factory standard job and binned my stainless lovelies (bast##ds)!!! Anyway, the O2 sensor is not on the collector (at least not on my car anyway). However, it can be on the GT car depending on age (it is on mine).
I think your question is about the exhaust joint on NA and turbo - if they are the same place? I can't say for sure short of taking the mid pipe off both cars. I can, however, compare my manuals with dfullerton's (he has the 1992 workshop manuals) to see. I take it you're trying to put a turbo exhaust onto your NA??
Kam
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1954253.34 ... 000239/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... =818426921>
Josh Colombo
Exhaust
Post by Josh Colombo »
yeah.....I'm considering.....or looking into turbo kit for my car. I won't probably do anything unless I have another car.......so I have a backup driver......plus I'm going to look into getting a house some time in 2003....depending where I end up after my last rotation at work.
I'd sooner not have to do the exhaust if I do it now....and then have to do it again later.
I'm going to an engines class this week.....I've learned some stuff about N/A to turbo conversions, and some stuff about turbo's and stuff.
I'll write-up some stuff when I get back in town.
-----Original Message-----
Sent: Wed 4/3/2002 8:23 AM
Cc:
Subject: Re: [BC-BFLegacyWorks] Exhaust
Josh,
Kam
ADVERTISEMENT
Kam
Exhaust
Post by Kam »
Couldn't you just borrow a car for a couple of weeks?
----- Original Message -----
Sent: Thursday, April 04, 2002 1:51 AM
Subject: RE: [BC-BFLegacyWorks] Exhaust
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=215002 ... =652504038>
Josh Colombo
Exhaust
Yeah I suppose I could do that.....or rent a car......It's too early to be saying when or if I will do it.
We'll see......
Sent: Thu 4/4/2002 3:35 AM
Cc:
ADVERTISEMENT
Doug Hancock
Exhaust
Post by Doug Hancock »
I think we got a little side tracted. Is there any horsepower difference from stainless to mild steel.
Sent: Thursday, 4 April 2002 11:37 PM
We'll see......
Cc:
ADVERTISEMENT
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=215002 ... =808098229>
Kam
Exhaust
Post by Kam »
Doug, an exhaust is an exhaust. Given two systems with identical physical geometric parameters (pipe bore, bend radii, muffler stuffing, welding consistency etc) I seriously doubt there will be any noticeable (if any at all) power difference. For the seriously technically oriented I suppose you could consider parameters like specific heat capacities and thermal resistance of mild and stainless - where one may hold heat than the other and hence improve gas flow. Without digging out reference on these parameters I would surmise that there is little difference in even these material properties - think what the difference is between a stainless saucepan and a non-stainless one...
From: Doug Hancock <mailto:Doug_hancock@optusnet.com.au>
Sent: Friday, April 05, 2002 24 PM
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=215002 ... =262766468>
Locked
