#3 not firing - help!
douglas vincent
Post by douglas vincent »
You do not have turbo injectors. They are pink.
That red one is a 270 cc NA injector. If you can make it to portland again, I will give you one.
woodrat
Post by woodrat »
I am actually going to Portland tomorrow AM. That would be awesome! Where are you located in Portland?
thanks!
1990 Legacy wagon, 340k miles, rusted out and retired to parts car status
1991 Legacy wagon, 232k miles
1994 Legacy wagon, 146k miles
1992 Dodge/Cummins W250 flatbed, 294k miles
1976 Mercedes 240D
1977 Mercedes 240D, 230k miles
BXSS
Post by BXSS »
DerFahrer wrote:Have you actually determined that #3 is not firing at all?
As in, have you tried maybe trying to arc the wire against a ground to see if it sparks?
Most cars with coilpacks use a waste-spark design. That means that the coilpack on a 4cyl engine, for example, only has two coils. In this case, the #1 and #3 plugs fire simultaneously, as do the #2 and #4. One of the sparks fires in the power stroke, like it's supposed to. The other fires I think in the exhaust stroke, essentially doing nothing, being 'wasted.'
So I don't think #1 is firing while #3 is not. You changing coilpacks and getting the same result is, to me, further indication of that.
Is the #3 injector stuck open, thus drowning the spark, causing the misfire, and soaking the plug in fuel?
HMMM, I thought 1/2 & 3/4 fired together.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
woodrat
Post by woodrat »
OK, replacing the injector was what I needed. Thanks to Douglas Vincent for kicking down an injector that was not only free, but it was even the correct one!
Rather than fool around pulling the whole fuel rail out, I made a tool for pulling the injectors, out of an old pair of needlenose pliers. Turned it into about a 3 minute job. Car runs great again.
Thanks to all!
1976 Mercedes 240D
93Leg-c
Post by 93Leg-c »
That's a nifty fuel injector puller you made for yourself. If I wanted to do the same, what do I do? It looks like you heated up the tip, then bent it. Does it have to be quenched in oil or some liquid after it's bent? And does the metal have to get to a certain color before bending it? Thanks for your help!
'94 TW
woodrat
Post by woodrat »
No, I didn't bother paying any attention to temper and I didn't quench it at all, just let it cool at room temp. I just heated it up and bent it. The first tip I actually got a little too hot and burned a bit of it away. It was literally about a 5 minute job, including dragging out the torch and lighting it up.
1976 Mercedes 240D
93Leg-c
Post by 93Leg-c »
Thanks! :D
'94 TW
