Check engine light goes out at steady speed?
Hey guys. I know I said my knock sensor seemed to be the reason for the code, but I removed it and inspected it, and saw no cracks, and the connector looks to be the newer updated one, looks clean like a new sensor. There was a MAF sensor code too. Need to check again though. What could be the issue most likely if the check engine light goes out at a steady pace, and when the engine is cool? I have a spare MAF sensor, it is the one N/A's use. Think I should pop it in? Anything else that can cause a code like this? Thanks guys!
Have you cleared the codes and checked again?
The canister purge solenoid can sometimes do some weird things.
Ok swapped out my good sensor from my N/A all is well!! So awesome how great this car is running. I am getting amazing fuel economy to I love this!!!!!!!!!!!! Now I need to fix the N/A since it needs a knock sensor, and it is getting MUCH worse fuel economy then the SS. I also found a odd hose broken. I am going to make a new thread.
