Some A/C questions.....
Ok I got some A/C questions and what not.
For those that don't know. I have a 90 Legacy N/A. I really haven't done much to engine yet. One thing I do have is an underdrive pulley.
Ok now for my questions. First one is my A/C is stinking....well not really the A/C itself, but when I use the A/C and then switch back to normal vents I get a nasty mildew odor. I have posted on another board as well. They have mentioned mold collecting in the evaporator box, and some solutions as to a spray you spray in the air intake to clean it out, or to use Lysol disinfectant spray.
Anyone take the evaporator box apart? How hard is it to get apart. I am pretty confident that the drain for the box is working. It still may need to be cleaned out some though. Anyone have this particular problem, and a specific resolution?
Second question/problem. My A/C pump is making a rattling when the engine is at idle. It sounds almost like a faint rod knocking on an engine. It's not really loud, but is audible from outside the car, and faintly audible from inside the car.
The noise goes away if I rev the engine a little. Also if I have been driving for a while, then come to a stop, it will not make the noise right a way. It may take a couple seconds before you can hear the noise.
My car has mainly been in the Northern part of the US where you would use the A/C occasionally. I have since then moved down to Houston, so I must have my A/C working, and working properly. The A/C was not run religiously on a monthly basis to keep the pump lubricated and what not.
The A/C still however produces rather cold air. When it's really hot, it does take a little while to get it kickin cold air out.
Soo....now for some of the questions. Seeing that my car is 12 years old, and has 154,000 miles on it. Would an A/C recharge be advisable? I will NOT convert over to 134a refrigerant. I'll get my grubby mits on some R12.
Do you think the A/C pump noise is being caused by lack of pressure in the system, and recharging it will boost the pressure back up and keep things cosure? Or do you think the fact I have an underdrive pulley on has any major ill effects. I have some of the calcs for speed differences between stock crank size pulley and the under drive one. It is very minimal. Something of the means of 200-300 RPM difference. I really don't know if that is enough to cause havoc or not.
If I get the A/C recharged, and the pump still makes the noise I will most likely just live with it till it dies. I'm not goin to drop a couple hundred dollars if it still works.
Thanks in advance for any help/comments.
PS: BTW, here is my site addy for some of the new folks or those that don't have it. www.surrealmirage.com/subaru I have more detailed info on stuff I have on my car as well as the ECU & TCU codes and retreival procedure, and some other stuff too.
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com **NEW**
of beats and rhythm" - ME
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1818248.33 ... 847665/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... =845590485>
Josh Colombo
ADVERTISEMENT
>From what I have seen I think it would be a real project to take the
evaporator box apart while it is in the car it is a bit of a project
when it is out of the car. We have had a few persons mention that they
didn't think the AC worked as well with a U/D pulley but it probably
is no big deal. I think I would have the pressures checked and not
bother recharging the system R12 doesn't wear out and you might
disturb a seal or something. On the pump what make is it? I might have
one if yours is going away. They used six different pumps and mounts
in the early cars.
AL(CO)
pulley.
the noise.
and what not.
not.
> Josh
> Josh Colombo
> <mailto:Josh@s...> Josh@s... **NEW**
Access Your PC from Anywhere
Check Email & Transfer files - Free Download
http://us.click.yahoo.com/omECdA/3XkDAA ... /XoTolB/TM
in the early cars.
AL(CO)
pulley.
the noise.
and what not.
not.
> Josh
> Josh Colombo
I'll get the numbers tomorrow, and a dig pic of the pump area tomorrow
before I leave out of town.
Thanks Al
josh
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com> **NEW**
-----Original Message-----
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Saturday, March 30, 2002 8:16 PM
Subject: [BC-BFLegacyWorks] Re: Some A/C questions.....
in the early cars.
AL(CO)
pulley.
the noise.
and what not.
not.
> Josh
> Josh Colombo
Your use of Yahoo! Groups is subject to
It's Easy. It's Fast. - Free Download
http://us.click.yahoo.com/lmECdA/6XkDAA ... /XoTolB/TM
Thanks Al
josh
Josh Colombo
in the early cars.
AL(CO)
pulley.
the noise.
and what not.
not.
> Josh
> Josh Colombo
It will also have a brand name such as Calsonic or Zexex
tomorrow
> Thanks Al
> josh
> Josh Colombo
> Josh@s... <mailto:Josh@s...> **NEW**
> From: milehial2000 [mailto:acroxford@h...]
> To: BC-BFLegacyWorks@y...
the
they
have
> in the early cars.
> AL(CO)
underdrive
> pulley.
back
evaporator
apart.
still
the
> the noise.
A/C
lubricated
> and what not.
my
pressure
drive
> not.
drop
> > Josh
codes
> > Josh Colombo
> BC-BFLegacyWorks-unsubscribe@e...
It's Easy. It's Fun. - Free Download.
http://us.click.yahoo.com/kmECdA/7XkDAA ... /XoTolB/TM
tomorrow
> Thanks Al
> josh
> Josh Colombo
the
they
have
> in the early cars.
> AL(CO)
underdrive
> pulley.
back
evaporator
apart.
still
the
> the noise.
A/C
lubricated
> and what not.
my
pressure
drive
> not.
drop
> > Josh
codes
> > Josh Colombo
Al,
I did some work on my car today.....the A/C pump is a Calsonic
compressor. it does make the noise still when engine is revved......it
really sounds like a bearing is going out.....I'm not sure whether to
just leave it go......or try and replace it....
Josh Colombo
Sent: Saturday, March 30, 2002 9:16 PM
tomorrow
> Thanks Al
> josh
> Josh Colombo
the
they
have
> in the early cars.
> AL(CO)
underdrive
> pulley.
back
evaporator
apart.
still
the
> the noise.
A/C
lubricated
> and what not.
my
pressure
drive
> not.
drop
> > Josh
codes
> > Josh Colombo
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
Josh Colombo
tomorrow
> Thanks Al
> josh
> Josh Colombo
the
they
have
> in the early cars.
> AL(CO)
underdrive
> pulley.
back
evaporator
apart.
still
the
> the noise.
A/C
lubricated
> and what not.
my
pressure
drive
> not.
drop
> > Josh
codes
> > Josh Colombo
Buy Stock for $4
and no minimums.
FREE Money 2002.
The one I have is a Zezex it looks close but they all do and every
compressor that they used needed a different mount. I went through
this on almost every conversion we did. Your compressor doesn't sound
good as most noises of this type get louder and louder but who knows?
The Calsonic is one of the more common ones.
AL(CO)
> Al,
revved......it
to
> Josh Colombo
> tomorrow
> > Thanks Al
> > josh
> > Josh Colombo
> the
project
> they
probably
> have
mounts
> > in the early cars.
> > AL(CO)
> underdrive
> > pulley.
stinking....well
> back
another
> evaporator
to
> apart.
> still
particular
> the
an
car,
have
the
hear
> > the noise.
> A/C
> lubricated
> > and what not.
really
> my
> pressure
and
underdrive
> drive
or
> > not.
> drop
> > > Josh
those
> codes
> > > Josh Colombo
Buy Stock for $4
and no minimums.
FREE Money 2002.
AL(CO)
> Al,
revved......it
to
> Josh Colombo
> tomorrow
> > Thanks Al
> > josh
> > Josh Colombo
> the
project
> they
probably
> have
mounts
> > in the early cars.
> > AL(CO)
> underdrive
> > pulley.
stinking....well
> back
another
> evaporator
to
> apart.
> still
particular
> the
an
car,
have
the
hear
> > the noise.
> A/C
> lubricated
> > and what not.
really
> my
> pressure
and
underdrive
> drive
or
> > not.
> drop
> > > Josh
those
> codes
> > > Josh Colombo
Buy Stock for $4
and no minimums.
FREE Money 2002.
yeah......I think I'm goin to just drive it......maybe have someone just
look at it......If I can get a compressor cheap....then maybe I'll
change it......if not....I'll wait till it breaks.......have any of you
guys done the R12 to 134a conversion......I want to make sure I get cold
A/C......but I've heard in general....the 134 systems are
beefier...because the refrigerant isn't as good......any thoughts??
Josh Colombo
Sent: Sunday, April 07, 2002 4:55 PM
AL(CO)
> Al,
revved......it
to
> Josh Colombo
> tomorrow
> > Thanks Al
> > josh
> > Josh Colombo
> the
project
> they
probably
> have
mounts
> > in the early cars.
> > AL(CO)
> underdrive
> > pulley.
stinking....well
> back
another
> evaporator
to
> apart.
> still
particular
> the
an
car,
have
the
hear
> > the noise.
> A/C
> lubricated
> > and what not.
really
> my
> pressure
and
underdrive
> drive
or
> > not.
> drop
> > > Josh
those
> codes
> > > Josh Colombo
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
AL(CO)
> Al,
revved......it
to
> Josh Colombo
> tomorrow
> > Thanks Al
> > josh
> > Josh Colombo
> the
project
> they
probably
> have
mounts
> > in the early cars.
> > AL(CO)
> underdrive
> > pulley.
stinking....well
> back
another
> evaporator
to
> apart.
> still
particular
> the
an
car,
have
the
hear
> > the noise.
> A/C
> lubricated
> > and what not.
really
> my
> pressure
and
underdrive
> drive
or
> > not.
> drop
> > > Josh
those
> codes
> > > Josh Colombo
Buy Stock for $4
and no minimums.
FREE Money 2002.
I don't think they are much better they just have a different oil,
expansion valve and 134. I went with it when I put my Lagacy turbo
motor in the Impreza and I can't tell the difference.
AL(CO)
just
you
cold
> Thanks
> Josh
> Josh Colombo
sound
knows?
> AL(CO)
> > Al,
> revved......it
> to
> > Josh Colombo
> > tomorrow
> > > Thanks Al
> > > josh
> > > Josh Colombo
take
> > the
> project
that
> > they
> probably
not
might
> > have
> mounts
> > > in the early cars.
> > > AL(CO)
> > underdrive
> > > pulley.
> stinking....well
switch
> > back
> another
> > evaporator
intake
> to
> > apart.
> > still
> particular
when
> > the
on
> an
> car,
> have
> the
> hear
> > > the noise.
you
The
> > A/C
> > lubricated
> > > and what not.
> really
12
be
get
> > my
> > pressure
> and
> underdrive
for
> > drive
havoc
> or
> > > not.
I
to
> > drop
> > > > Josh
> those
> > codes
> > > > Josh Colombo
Buy Stock for $4
and no minimums.
FREE Money 2002.
AL(CO)
just
you
cold
> Thanks
> Josh
> Josh Colombo
sound
knows?
> AL(CO)
> > Al,
> revved......it
> to
> > Josh Colombo
> > tomorrow
> > > Thanks Al
> > > josh
> > > Josh Colombo
take
> > the
> project
that
> > they
> probably
not
might
> > have
> mounts
> > > in the early cars.
> > > AL(CO)
> > underdrive
> > > pulley.
> stinking....well
switch
> > back
> another
> > evaporator
intake
> to
> > apart.
> > still
> particular
when
> > the
on
> an
> car,
> have
> the
> hear
> > > the noise.
you
The
> > A/C
> > lubricated
> > > and what not.
> really
12
be
get
> > my
> > pressure
> and
> underdrive
for
> > drive
havoc
> or
> > > not.
I
to
> > drop
> > > > Josh
> those
> > codes
> > > > Josh Colombo
Buy Stock for $4
and no minimums.
FREE Money 2002.
r12 is expensive as hell. after checking out the price, you'll start
considering 134 a lot more.
-Jason
>From: "Josh Colombo" <josh@surrealmirage.com>
>Thanks
_________________________________________________________________
Join the world’s largest e-mail service with MSN Hotmail.
http://www.hotmail.com
Buy Stock for $4
and no minimums.
FREE Money 2002.
-Jason
>Thanks
Buy Stock for $4
and no minimums.
FREE Money 2002.
Price aside......what about cooling capabilities.....that's what I guess i'm most concerned with.....how well will it cool.
Sent: Mon 4/8/2002 11:44 AM
Cc:
Subject: RE: [BC-BFLegacyWorks] Re: Some A/C questions.....
-Jason
>Thanks
Buy Stock for $4
and no minimums.
FREE Money 2002.
Cc:
-Jason
>Thanks
Buy Stock for $4
and no minimums.
FREE Money 2002.
