Car starts shimmying around 50 mph or so, not noticeable below those speeds. It shakes no matter what gear (3rd, 4th, 5th) or regardless of if the clutch is in or out, or if the trans is in neutral or not. Shakes while braking until you're below the 50mph threshold, too.
Only seems to occur after it's driven for a while, 5 or so minutes. Comes and goes.
No odd noises are heard (i.e. squeaking or whirring)
I thought it was a balance issue, so I took it to a shop to get the 14" OEM steel wheels with tires, rebalanced, rotated, and retorqued. Occurred again less than 24 hours later.
I think it's rotational. You can feel it all through the car, in the steering wheel and in the shifter.
Thoughts, comments? I've had to park her
