how to fix idiling
how to fix idiling
read that it should be 600 to 800. mine when started usaully is at 2000 sometimes 3000 then it slowly climbs down to about 1000. i have used the cables near the TB to adjust the idil( i can never remember how to spell this word for some reason). these would be the throttle cables i sure. but maybe im doing it wrong.
if the idle is too high there is something else wrong... bad IAC, vacumn leak (bad, broken, or loose hose), O2 sensor... something. the Subie's aren't like a carbuerated engine where you just back the idle down.
My wagon did something similar but the lowest idle was about 1400 indicated. I replaced the IAC with a used one from the pull a part, and everything went back to normal...
'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
Re: how to fix idiling
Mine has always done this when cold. Cold starts out around 2,000 rpm and as the engine warms up, it slowly goes down to ~600 rpm.SILINC3R wrote:read that it should be 600 to 800. mine when started usaully is at 2000 sometimes 3000 then it slowly climbs down to about 1000....
This is wrong?
'11 WRX Limited
'94 TW | R.I.P.
Saskatoon Subaru
This is not wrong, every car i have ever started when cold the engine will rev up until the engine warms up a bit, don't worry about itBSOD2600 wrote:Mine has always done this when cold. Cold starts out around 2,000 rpm and as the engine warms up, it slowly goes down to ~600 rpm.SILINC3R wrote:read that it should be 600 to 800. mine when started usaully is at 2000 sometimes 3000 then it slowly climbs down to about 1000....
This is wrong?
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Okay, I was reading it as the idle was staying high, up around 1000 after it warmed up and he was trying to get it back down into the 600-800 rpm range.
I just know that when my IAC started to fail the warm idle gradually crept up until it wouldn't go under 1400 rpm. took about 2 months for it to get to that point.
If it's around 800 then yes, leave it alone... if it's higher DO NOT try to adjust it down using the cables or the idle stop screw on the TPS.
where is the IAC. what does it do and how much to replace.tahiti350 wrote:Okay, I was reading it as the idle was staying high, up around 1000 after it warmed up and he was trying to get it back down into the 600-800 rpm range.
also what is wrong if i mess with the idle screw cause im sure i messed with it a little. not much though
The IAC is on the right side of the throttle body (left side when you are standing in front of the car). The IAC "Idle Air Controller" is basically almost like a choke for a fuel injection vehicle. It allows more or less air to bypass the throttle body to increase RPMs to help warm up the engine. As for how much to replace, I can't help you on that one, sorry.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
06 ZZR600
I got mine at the wrecking yard for $5...
Also the idle set screws are set at the factory, and the computer uses that setting as a baseline. The computer varies the IAC postion to add or subtract air to regulate the idle speed. if the IAC is failing it may either go full closed or most likely full open, which raises the idle and affects drivability.
altering the idle screw confuses the computer... Don't ask me how I know this....
dang... looks like i might needa trip to the old junk yard
