2001 Legacy Manual Transmission whining/grinding/noises...
apriddy4
Post by apriddy4 »
We recently purchased a 2001 Subaru Legacy GL Manual with nearly 60,000 miles on the odometer.
The car runs great, except for an issue with the transmission.
When taking off from 1st gear (or from reverse) you hear a whine/grinding noise and typically smell the clutch burning…but only if you launch ABOVE 1k rpms. When launching below 1k rpms, everything appears to be normal. The fluid levels are fine, and I haven't noticed any other issues.
Has anyone heard of this?
We just purchased the vehicle and really aren’t looking forward to dropping more cash into it.
Thanks for any help!
Welcome to the board.
It could be anything really. Does the whine/grinding match engine speed?
apriddy4
Post by apriddy4 »
Legacy777 wrote:Welcome to the board.
No, it doesn't. I'll be taking it to a clutch shop this week.
Airgne
Post by Airgne »
i had the same issue with my 01 legacy, but mine had a front snout leak. my clutch bearing had gotten cocked on the snout. subaru tranny snouts are not one peice they are 2 hlfs put together. so over time they missaline with each other. this causes the clutch bearing to get cocked and then wear on the pressure plate causeing it to wear a groove on the teeth of the pressure plate. witch intales a werid grinding noise when starting out and going in reverse. i bought a new tranny for mine(because of the seal leak, also my rev gear was goin out). if i were you i would go and get a snout repair kit and a new clutch. the snout kit for your tranny, and the clutch just incase it hasd a groove worn in the pressue plate teeth.
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
apriddy4
Post by apriddy4 »
Airgne - thanks for the info! I'll be taking my vehicle to the "clutch shop" today and I'll be surprised if they don't diagnose the problem like you have. I just hope it's not an "arm and a leg!"
Airgne wrote:i had the same issue with my 01 legacy, but mine had a front snout leak. my clutch bearing had gotten cocked on the snout. subaru tranny snouts are not one peice they are 2 hlfs put together. so over time they missaline with each other. this causes the clutch bearing to get cocked and then we.......
These things are pretty handy to help solve that issue...
http://www.smart-service.com/store-tran ... e-kit.html
Airgne
Post by Airgne »
no problem man. hope you can get it fix for a good price. it pretty easy to do yourself.
apriddy4
Post by apriddy4 »
Thanks for the site.
When y'all (yes, I'm originally from Texas) say "it's easy to do yourself," how easy do you mean?
I've done typical "bolt-on" modifications to one of my previous cars (1998 Trans Am) and I don't really have all of the tools I usually have at my disposal currently.
Thanks.
Airgne
Post by Airgne »
it took me with 1 freind and minimal tools 5hrs in and out. we had never done this on a subaru before. 4 jack stand a jack, and some basic tool ull be good.
Airgne
Post by Airgne »
if you go over to sli-.net there is more infor on the newer legacies.
apriddy4
Post by apriddy4 »
Thanks again Airgne!
apriddy4
Post by apriddy4 »
The shop installed a new clutch and dual mass flywheel. Everything is working, so I'm happy. Hopefully it won't ever happen again!
