You guys with the Kg/mm vacuum.....I think we got some unit issues.......unless I'm not fully understanding everything.
kg/mm of vacuum cannot be converted to PSI.....it's not the same unit of measure. kg/mm*mm is the same unit of measure as PSI....but that wasn't what you guys used.
My thinking is that kg/mm is in relationship to either water or mecury....mmHG and mmH2O are units of pressure.
The only other thinking is it is just a straight up....how many mm does it take to put a certain kg force and move the fluid level in a manometer up a certain amount..........If so.....I have no freakin clue how to convert it to PSI.......
Did find a pretty cool page during my quest for some answers http://www.wsdot.wa.gov/Metrics/factors.htm
-----Original Message-----
Sent: Fri 4/12/2002 61 AM
Cc:
Subject: Re: [BC-BFLegacyWorks] boost & vacuum
From the top of head I idle at 500kg/mm vacuum
----- Original Message -----
Sent: Friday, April 12, 2002 4:51 AM
Subject: [BC-BFLegacyWorks] boost & vacuum
While looking at the boost gauge at idle what should
the vacuum be at assuming the gauge is accurate. (for
an ej22t)
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.1994012.34 ... ?code=3466> Click Here!
<http://us.adserver.yahoo.com/l?M=194081 ... =510053320>
vacuum units......
legacycentral
vacuum units......
I'm pretty sure mine reads in kg/mm*mm, but i didn't want to go to
the character sheet and find the superscript to make it squared.
> Josh
> From: Kam [mailto:kam@s...]
> To: BC-BFLegacyWorks@y...
> Cc:
> From: Nissan-Subaru <mailto:nissans14@y...>
> an ej22t)
> Do You Yahoo!?
to:
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service <http://docs.yahoo.com/info/terms/> .
> ADVERTISEMENT
> Click Here!
<http://rd.yahoo.com/M=194081.1994012.34 ... upweb/S=17
05064983:HM/A=1036972/R=0/*http://www.ediets.com/start.cfm?code=3466>
M=194081.1994012.3473453.1261774/D=egroupmail/S=1705064983:HM/A=103697
2/rand=510053320>
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
> Josh
> Cc:
> an ej22t)
> Do You Yahoo!?
to:
> ADVERTISEMENT
> Click Here!
2/rand=510053320>
Buy Stock for $4
and no minimums.
FREE Money 2002.
Kam
vacuum units......
I think it would help if a little assumption is used - obviously pressure is measured in units of force over area. It's not difficult to work out when someone is talking about kg/mm*mm but types kg/mm. However, it is more misleading if we happen to use mm instead of cm or m where we can be an order(s) of magnitude out which is far more confusing.
From: legacycentral <mailto:legacycentral@yahoo.com>
Sent: Friday, April 12, 2002 2:21 PM
Subject: [BC-BFLegacyWorks] Re: vacuum units......
> Josh
> Cc:
> an ej22t)
> Do You Yahoo!?
to:
> ADVERTISEMENT
> Click Here!
2/rand=510053320>
ADVERTISEMENT
<http://rd.yahoo.com/M=217097.2003762.34 ... ge=account>
<http://us.adserver.yahoo.com/l?M=217097 ... =956558243>
> Josh
> Cc:
> an ej22t)
> Do You Yahoo!?
to:
> ADVERTISEMENT
> Click Here!
2/rand=510053320>
ADVERTISEMENT
Kam
vacuum units......
Actually a kg/mm*mm is not the same unit as PSI - although they both measure pressure.
Sent: Friday, April 12, 2002 1:58 PM
Subject: [BC-BFLegacyWorks] vacuum units......
Cc:
an ej22t)
Do You Yahoo!?
ADVERTISEMENT
Click Here! <http://rd.yahoo.com/M=194081.1994012.34 ... ?code=3466>
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=217097 ... =270897207>
Cc:
an ej22t)
Do You Yahoo!?
ADVERTISEMENT
ADVERTISEMENT
