I have access to a full set of seats from a 2005 Subaru 2.5i sedan. The front seats in my touring wagon are flat from the big boned lady who owned it before me. I found one post that says that 2004 seats will fit, but
-I just wanted to see if they are a direct bolt on,
-Do they have the same height problems of the wrx seats?
What about the rear seats?
2005 Legacy seats in a 1994 Wagon
turbodrabbit'
1994 Turbo Wagon
1999 Subaru Forester
Front seats are a bolt-in, but will sit higher, as you suspected. About 1.5" higher at the lowest setting.
Rear seats are completely different between sedans & wagons, and incompatible. You might be able to adapt the upholstery if you have a decent sewing machine...
Jerry
