I posted a msg about having pulsing like power, I was told I need
boost control solenoid, could it be the sensor? Both are a bit
expensive, can I couple the 2 hoses together that go in and out of
the solenoid temporarly and see if that fixes it?
Matt
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA ... /XoTolB/TM
93 Legacy turbo
legacycentral
93 Legacy turbo
You can do just that.
Run the two lines together and the wastegate spring should open
between 6 and 7 PSI. You'll feel a drop in power, but it should
eliminate the stuttering problem, if the solenoid is indeed the cause.
> Matt
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
> Matt
Buy Stock for $4
and no minimums.
FREE Money 2002.
