overheating issue...
Snowolf2
Post by Snowolf2 »
My 93 NA Leggy runs a bit hot after driving for a while. If I turn the heat on full blast, the needle moves back to the middle. But summer is coming and driving with the heat on will not be fun... how do I fix this?
2001 Impreza RS, 5spd
1993 Legacy L 5spd wagon - sold
joeWM
Post by joeWM »
check your coolant. make sure its good and filled
[quote="kimokalihi"]Jesus, that's a grocery list of problems.[/quote]
92 Legacy SS 5MT....sold :(
02 Aspen white WRX Stage 2, 20%tint
dscoobydoo
Post by dscoobydoo »
Mileage?
radiators do get clogged and go bad.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Snowolf2
Post by Snowolf2 »
165,000mi... not sure when the last time the radiator was replaced. I'll check the coolant level today, though I am pretty sure it was filled just 3mo ago.
Blackbart
Vendor
Vendor
Post by Blackbart »
Head gasket??
Skruyd
Post by Skruyd »
Snowolf2 wrote:165,000mi... not sure when the last time the radiator was replaced. I'll check the coolant level today, though I am pretty sure it was filled just 3mo ago.
Plenty enough time for a leak to develop. But yea, when you turn the heat on. Is it the defroster? The radiator fan might have gone out, or relay died and the other fan kicks on if you turn the defroster on for the A/C.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
Snowolf2
Post by Snowolf2 »
Yeah, its when I turn on the defroster. I checked the coolant and it was VERY low to my surprise, since it was supposedly filled just 3mo ago... Anyways, its full now, so I'll see if the problem continues.
joeWM
Post by joeWM »
mine had a leak and over time would drain out mainly during driving because of the pressure they are under. bought a new one and problem solved
Snowolf2
Post by Snowolf2 »
yeah, I gotta keep checking for leaks
