![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
BAD GAS MILEAGE!!
BAD GAS MILEAGE!!
Shawn
91 Legacy SS AT
93 Legacy L Wagon
To get your hands on superior lubricant products from AMSOIL utilize the following url:
http://www.amsoil.com/redirect.cgi?zo=1819626&page=store
91 Legacy SS AT
93 Legacy L Wagon
First step is to fix any current problems that you know about. You had quite a list there. I would do all of them before any mods, not after or during.
Mileage is most commonly the O2 sensor, TPS or vaccuum leaks. It can be others though, especially when you know you have multiple issues. They kind of play off of each other.
My suggestion is to go back to square one and deal with everything you currently know about. Then deal with any codes. Troubleshoot and fix your mileage problem. Then, start your upgrade process. You will be time, and money, ahead in the long run.
Like i said i got the cel to go off finally. I did not change the tps though. I am actively searching for vacuum leaks. So as i didnt not think that the new fuel pump would cause it to start sending excessive gas but i do not know for sure.
Shawn
91 Legacy SS AT
93 Legacy L Wagon
91 Legacy SS AT
93 Legacy L Wagon
If the regulator is bad, then a new pump would raise the fuel pressure. This would dump extra fuel anytime your not in closed loop.
I have had suspicion that the regulator may not be working correctly, is there anyway to test it or do you just replace it. I would imagine vacuum testing it would be a solution? As I understand it that even if the pump flows more the regulator would do just that, regulate it, and send the excess fuel back into the gas tank.PhyrraM wrote:If the regulator is bad, then a new pump would raise the fuel pressure. This would dump extra fuel anytime your not in closed loop.
asc_up: I actually just replaced the oxygen sensor in this string of getting sensors replaced. It has been about a month and a half.
Thanks for the info.
Shawn
91 Legacy SS AT
93 Legacy L Wagon
91 Legacy SS AT
93 Legacy L Wagon
Put a fuel pressure gauge on it. If it's out of spec (service manual is around here for D/L somewhere), either the pump is too big or the regulator is bad. Could be a blocked return line also.
A O2 can go bad very fast if the car is not running right. Both too rich or too lean OR a bad O2 heater circuit can crush an O2 sensor.
Thanks for the information i will search for that manual. I will report when i find out information from this. Thanks again.PhyrraM wrote:Put a fuel pressure gauge on it. If it's out of spec (service manual is around here for D/L somewhere), either the pump is too big or the regulator is bad. Could be a blocked return line also.
Shawn
91 Legacy SS AT
93 Legacy L Wagon
91 Legacy SS AT
93 Legacy L Wagon
Ok I put the a gauge on the fuel line and it read 35 psi at idle and i revved it up and it showed about 45-50. I thought that fuel injection was around 32 psi but the Chiltons manual says it should read 2.6-3.3 psi. Thats really low i would think. What am I missing here? Bad fuel pressure regulator?
Shawn
91 Legacy SS AT
93 Legacy L Wagon
91 Legacy SS AT
93 Legacy L Wagon
Idle seems OK, but I don't think it should jump that much when revved. Could be wrong though. What does the FSM say about off idle pressure?
Fuel pressure should rise 1 psi for every psi increase in manifold pressure. Vaccuum included, so "less" vacuum is seen as 'more' pressure to the regulator.
Ok good info. I noticed the vacuum line to the regulator came off and i put it back on and zip tied it to hold it. This may help a lot I will update if I find a difference as there should be a huge difference. The only thing is that it didnt really make a difference in the vacuum on the gauge or the boost. Which is weird.
Shawn
91 Legacy SS AT
93 Legacy L Wagon
91 Legacy SS AT
93 Legacy L Wagon
Ok I got bored and smacked the Catalytic and it seems to run different. Last I knew the cat looked clean inside. I am starting to wonder if it is plugged up a bit and is causing backpressure and also resulting in bad gas mileage. Still now CEL though. Sound like a good direction, look for a dp?
Shawn
91 Legacy SS AT
93 Legacy L Wagon
91 Legacy SS AT
93 Legacy L Wagon
Yeah im wondering that too...I did do seafoam through the intake and it definitly cleaned things up it runs smoother and blew out all kinds of carbon build up. I found my two leaks bc of the smoke too...I have one where my BOV mounts on my intake and also one small one on the turbo to downpipe gasket because i need a new nut to go on the stud bc it was missing found one but it didnt seal it as i dont believe it was the right nut for it. I will be puting on a intercooler and getting the proper mounting adapter and that should take care of the bov leak since its just bolted to the factory pipe where the bpv used to be.
Shawn
91 Legacy SS AT
93 Legacy L Wagon
91 Legacy SS AT
93 Legacy L Wagon
I just filled up the tank and calculated 16 mpg instead of 12-13!! Headed in the right direction....next up that pesky vacuum leak.
Shawn
91 Legacy SS AT
93 Legacy L Wagon
91 Legacy SS AT
93 Legacy L Wagon
