1993 Subaru Legacy Turbo Wagon
not winter driven for two years. 3rd owner this is my daily driver it is fast and handles well, it is a total sleeper.
2.2L 4cyl Turbo EJ22T
saftied til October.
Solid Engine
Solid Frame
Solid floors
Glass is good
Interior is decent no rips could stand to be cleaned
new Exhaust from the Turbo back
new Aluminum radiator
new Alternator
rebuilt Starter
new Plugs and wires
new gas tank
new air filter
new drilled routers and pads last summer
(5000km) Michelin hydro edge tires
new belts
new rear brake lines
new fuel filter
new fuel lines
new emergency brake shoes
new rad hoses
250 000 km's
It needs
a right rear cv boot - <still driveable>
new sunroof trim
The sunroof is intermittant it sometimes wont close when you want
We are surrounded by ocean and use Salt in the winter
rear wheel wells are rusted but easilly fixed
the right rear door sill at the wheel well is soft (3x2 inch) and should be cut out.
the drivers door needs some sanding
the glass pushes in when you raise the window, in order to close the window the extra half inch, i have to open the door and close the window
ABS light is on and i dont know why could be the pump or a sensor
power steering is not working, could be the pump or a bushing, the rack is fine it still holds fluid.
to go along with this car i have 2 rear KYB GR2 struts in the box and a decent complete rear hatch with wiper.
The car is located in Halifax, Nova Scotia
Will accept trade offers on 1970s and 1980s conversion vans
http://www.flickr.com/photos/36923774@N07/3469491415/
http://www.flickr.com/photos/36923774@N07/3470305046/
http://www.flickr.com/photos/36923774@N07/3470304576/
fs: 93 legacy turbo wagon 1400cdn
93 Legacy Turbo Wagon EJ22T
98 Legacy Brighton EJ22E
01 GTP Special Edition 3.8L Supercharged
