custom guage cluster #More pics#
Post by SILINC3R »
not totaly done yet. all that i have left to do is put the gauges in. wait till you see what im using for my speedo
oh yea and this is real carbon fiber not fake
let me know what your thinking
I'm thinking....why is this guy putting carbon fiber into a rattle canned gauge cluster trim piece. Are you serious? lol I'm going to assume you're going to paint that or you're just using it for a mock up so you don't have to remove your unpainted gauge cluster trim from your car until the carbon fiber is ready.
Post by SILINC3R »
lol, no thats the only trim piece i have and it will either be repainted or i will paint it black.
Post by SILINC3R »
its done, well for the most part. still have to find some LEDs for the blinkers and highbeams and that should do it. as well as a fuel guage
How is the car with the rebuilt motor?
Btw are you putting that over the original gauge cluster?
Dude pull all those interior pieces and repaint them black lol!!!!
Post by SILINC3R »
it fells so good now. when i shift it doesnt boog down and sounds so much better. however it isnt fully rebuilt :( just cleaned heads with valve job and new seals and gaskets. but no leaks at all :-D
yea i goes over the old cluster. so if ineeded to i could just take it off and the old one would be right there
Good. I am sure the motor has just as good of compression as new anyways.
Post by SILINC3R »
more pics
Not bad. Now go to the junkyard and get a new matching glovebox and gauge cluster trim and de-rice your poor car!
Do you have the gauges set back far enough where you don't get any reflection on the windshield at night?
asc_up
Post by asc_up »
So what exactly are all of the gauges and what happened to the one of the far right?
And are you using your GPS for a speedometer? Have you tested its accuracy?
Post by SILINC3R »
yea i think im going to repaint it with that plastic dip stuff.
yea there is no glare at night
far left is water temp, then tach, then GPS, will be fuel guage(just have to get one and figure how to wire it up)
bottom left oil temp then volt
yes GPS is for speed and i figured it was very accurate. how would i check. my speedo used to kind of get stuck after i put the white face guages on so it wasnt very accurate.
asc_up
Post by asc_up »
Ah well I would test the accuracy of the GPS in another car then, especially if you can find a car with a digital speedo (such as an S2000), but any car will do. That way you can make sure that it reads within 1-2 MPH of any given speed.
PS, you should try to wire up a light for the CEL, that way you'll know if something bad is happening.
Post by SILINC3R »
well it has never come on in the 3 years that i have had the car, so either the bulb is broke or maybe it doesnt have one or maybe there is nothing ever wrong with it :D
asc_up
Post by asc_up »
That just means that you're 3 years closer to it finally coming on :D
Aerotech
Post by Aerotech »
GLowshift gauges?
Jerry
Post by SILINC3R »
asc_up wrote:That just means that you're 3 years closer to it finally coming on :D
lol yea maybe
yes they are glowshift guages
i have used them for all mine. great price and great product. they just came out with a new product and are pretty good. might get those on the next car
here
Mattheww044
Post by Mattheww044 »
damn thats crazy, talk about custom. Good work
Re: custom guage cluster #More pics#
Post by SILINC3R »
Oh, the glory days of being fast and furious
Lol that's what you had when I met you Tony. Plus the headliner
