can someone please tell me the difference in these 3 turbos.
IHI-VF34 Roller Bearing Turbocharger
IHI-VF22 Roller Bearing Turbocharger
IHI-VF36 Roller Bearing Twin-Scroll Turbocharger
Questions such as...what psi output, full boost at what rmp, and what is "twin-scroll"?
Turbocharger Difference?
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
-74 Yamaha rd 350
This will give you a headstart: http://www.stealth316.com/2-3s-compflowmaps.htm
There is also a thread on nasioc with some detailed info bout the various VF* turbos.
'11 WRX Limited
'94 TW | R.I.P.
Simply put ( in case you are lazy LMAO)
VF-36/37 are the twin scroll turbos ( meaning they separate the exhaust channels into two paths "twin scrolls" ) Standard turbos use one path for the exhaust gases.
The VF-22 is an early large turbo, roller bearing. ( GC chassis STI/WRX coupe/sedan)
The VF-34 is a later series Ball bearing turbo. ( Sti GDA/GDB sedan)
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
