After reading the FSM for inspection / replacement of the HLA's, it seems too easy. One thing I've learned from my car, is that 'simple' little tasks are ALWAYS filled with 'gotchas', often not documented.
1) I don't need to drain the oil to remove the rocker covers, right?
2) Really one can simply push in the top of the HLA to test if they're hard/soft?
3) I only need to loosen the bolts on the valve rocker assembly to release/remove the HLA's?
4) 12 N-m torque (for the rocker assembly bolts) is just basically finger tight? I don't have a wrench which goes that low.
Anything else the FSM doesn't cover?
HLA checking
HLA checking
'11 WRX Limited
'94 TW | R.I.P.
Re: HLA checking
Yea, don't drain the oilBSOD2600 wrote: 1) I don't need to drain the oil to remove the rocker covers, right?
Only for the intake because they are singles. The exhaust has two valves per cam lobe so it's a little tougher to see if one needs to be bleeded out if the other doesn't.BSOD2600 wrote: 2) Really one can simply push in the top of the HLA to test if they're hard/soft?
Yup. take the eight bolts out evenly. The center bolts on the rocker ends are to keep the ends on the rod.BSOD2600 wrote: 3) I only need to loosen the bolts on the valve rocker assembly to release/remove the HLA's?
Yes 12 N/m or 9 ft/lb or if you have an inch pound torque wrench 108 in/lb. If you are worried about the spec find an in/lb wrench.BSOD2600 wrote: 4) 12 N-m torque (for the rocker assembly bolts) is just basically finger tight? I don't have a wrench which goes that low.
Can't really think of anythingBSOD2600 wrote: Anything else the FSM doesn't cover?
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
06 ZZR600
