Anybody have the lift and timing data for the '96 EJ25 DOHC cams? These are the heads with the hydraulic buckets.
I have a set of these and I think they will fit into the '98 shim over bucket heads i'm gonna use. Just wondering if the '96 cams would be any better than whats in the heads now. The '97-'98 EJ25 DOHC cams thave the split duration in the exhaust cams.
Gary
Cam Specs for '96 EJ25 ?
All_talk
