I have been using a MBC, but I feel like checking to see if the stock solenoid works or not. It was "broken" when I bought the car for the engine swap.
I have searched, but everything refers to an old diagram that can't be accessed anymore.
The solenoid has 3 fittings: 1 on the bottom, 1 on the side near the bottom, 1 coming out the top.
I'm guessing: Bottom=compressor, Side=Wastegate, Top=Bleeder.
I'd like to be sure i have it on correctly before I declare the solenoid broken.
Stock Boost Solenoid Hose/Fitting Diagram?
Just covered a few days ago: http://bbs.legacycentral.org/viewtopic.php?t=39925
'11 WRX Limited
'94 TW | R.I.P.
