So I tried searching around the forum with no luck... I was wondering if anyone knows of a place that might sell up-pipe and down-pipe turbo flanges? Preferably in 304SS... I wanted to make a more efficient up pipe for my VF11 or TD04 but wouldn't want to have to reuse the mild steel original flanges if I'm going to use 304stainless. Any help would be much appreciated! Thanks in advance.
- Martin
Where To Find Some Subaru Related Turbo Flanges...
91 Legacy Turbo SS
92 Legacy Ls AWD Wagon
Drift King.
Drift King.
Why do you need it stainless steal? If you weld it, it's still going to rust.EJ22T DK wrote:Thanks a bunch dude! To bad the flange on the ebay link is just steeL! DOH!! Thanks a bunch for the find though! I shot off an email to them to see if they might have them in stainless...![]()
- Martin
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
06 ZZR600
Give it some years. It will rust. Nothing last forever. Pi even endedEJ22T DK wrote:If I TIG weld it nicely with some stainless filler.... It most certainly should NOT rust
- Martin
06 ZZR600
06 ZZR600
Just a thought, but you can get a SS up-pipe by itself fairly cheap, any turbo Subaru up-pipe will fit... Ebay stuff, again, go for the no-name el-cheapo, but they're fairly good metal and really nicely welded.
I actually have one sitting around somewhere, if I can dig it out, I'll let you know, I completely forgot I had it.
Jerry
Thats good to know... I might consider that, I'll have a look around... The truth is, I'm new to fabrication so I'm still kinda learning... Right now I'm obsessed with welding anything that can potentially save SOME money or just stuff that I know i can do better then what is available... Not to mention if i make my own up-pipe, I'll change the angle of the turbo slightly to make for better FMIC plumbing and cold air intake and so on... But if you wouldn't mind snapping a few pics perhaps of the up-pipe you got kickin around... Do you know what the Inside Diameter of the flange on it is? Thanks in advance
- Martin
- Martin
91 Legacy Turbo SS
Drift King.
Drift King.
