Moderators: Helpinators , Moderators
Posts: 27934 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Thu May 28, 2009 1:52 am
If the green ones are connected, they "should" cycle.
That image is mislabled as far as the ECU goes.
This image is better
On some of the 92-94 models, the green connectors are on the right of the steering wheel. Look some more for the connectors.
Posts: 3242 Joined: Mon Oct 16, 2006 9:44 pm
Post
by ericem » Thu May 28, 2009 2:54 am
So if they green ones are connected they will cycle. So your saying they have to be connected. Now I am officially confused.
Post
by Legacy777 » Thu May 28, 2009 2:59 am
No I'm not saying they are connected. I'm just saying that when the green connectors are connected and the key in the ON position, but engine not started, the fans will/should cycle on and off every few seconds, regardless of engine temp.
I'd highly recommend finding the green diagnostic connectors and verify they are not connected.
