Trunk execution, how to cram stuff and make it look OK?
asc_up
Post by asc_up »
Holy crap. I wish I had the patience to fabricate things like that. That's awesome!
PhyrraM
Post by PhyrraM »
That looks sweet Mike. Was that well in the cargo area OEM or did you fabricate that also.
A co-worker came up with a likely solution to the huge air tank. Schedule 80 PVC pipe and fittings. I can assemble as many smaller tanks as neccisary for the volume I decide on. They can be mounted almost anywhere there is free space, and I can network them together with the polytube.
magicmike
Post by magicmike »
PhyrraM wrote:That looks sweet Mike. Was that well in the cargo area OEM or did you fabricate that also.
That fit right in the factory space in the back. That system was sweet! I had 4 10" subs, an 8" midbass, a 4"midrange and tweeter in each door. Alpaine deck, alpine EQ, audio control 4Xs set up in 4 way stereo mode, two batteries, two caps, two Ref500's and a Ref 404s totalling 1500 watts. It was pretty nice :) It was my demo car for my custom fabrication business.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
PhyrraM
Post by PhyrraM »
Saw another site (A Halloween Haunting site, no less) that champions converting used propane cylinders for air storage use. They use the small ones for camping stoves and such.
Probably better than PVC.
The more I think about it, the more I am leaning towards placing the air storage in the front passenger side fenderwell. That would leave only the valveblock and the audio gear to put in the trunk.
PhyrraM
Post by PhyrraM »
On a roll....I found a '06 WRX spare. That gives me the area taken up by the utility tray back. Maybe enough area for amps and the digital pre-amp? We'll see.
Lego
Post by Lego »
those amps are nice, im glad you go for good stuff and not that Chinese garbage, your amps are packed inside, the Garbage amps have like nothing in them...
1992 legacy h6
1998 legacy gt sedan: for sale soon
