1991 Subaru Legacy SS Turbo Sedan
WRX EJ20G
Rob Tuned EJ20G ECU
JECS MAF
Forester 4.444 Trans+Diff
TD05 18G Turbo
525CC STI Yellowtop Injectors
JECS MAF
Impreza GC Tein Type HT Coilovers
20mm Whiteline Rear Bar w/20mm WRX Wagon Front Bar
Rota DPT 17x9 General Exclaim UHP 225/45/17
STI Front Lip
WRX Hood Scoop and TMIC
WRX Front and Rear Seats
Rally Armor Mud Flaps
Index:
Page # - Mod w/Link
2 - Timing Belt, Shifter Bushings
3 - Valve Cover Gaskets, Paint
5 - Throttle Body Spacer Fabrication, Phenolic Intake Spacers, Header Wrap, Group N Mounts
7 - Clutch, Lightweight Flywheel
8 - Engine, Trans Install
9 - Canadian Manual Seatbelts, Canadian Headliner
10 - ASI Silicone Intake, Sunroof Replacement
12 - Whiteline RSB
19 - TMIC
20 - BPV Fab, Walbro 255 Fuel Pump, 20mm WRX Front Swaybar
21 - Custom Hi-flow Catted DP, O2 and Innovate LC-1 Wideband, TD05 18G w/Heat Blanket
22 - TD04 + TD05 Comparison,
23 - Rob Tuned EJ20G ECU, Injector Adapter Kit, Tein Type HT Coilovers
24 - Yellotop 525cc Injectors, Simply Subie Fender Braces
25 - New Clutch Master and Slave Cylinders, Wiper Fluid Reservoir Relocation
29 - Fuel Leak, Rob Tuned ECU Install, Mouse Nest Massacre, New Speedo Cable
30 - AC Evap Delete
31 - Hallman MBC Install
33 - Rota 17x8 DPT's w/General Exclaim UHP 225/45/17
35 - AC Condensor Delete, Custom Battery Tie Down
37 - Custom Grill, WRX Hood Scoop
39 - Black and White Photoshoot
40 - Stripped Crank Pulley Keyway
42 - New Crank Sprocket, New Crankshaft Key, Blown Engine
44 - Engine Removal
45 - Blown Piston Rings, Injectors Cleaned and Flowtested
47 - New (to me) WRX EJ20G Shortblock
48 - Gaskets, Seals, Oil Pump, Engine Assembly
49 - Engine Installed
50 - Back On The Road
52 - New Rob Chip
53 - Rally Armor Mud Flaps
