N/A Power
shemeryahu
N/A Power
Now that I have my suspenstion complete, I'm looking at ways to boost
my power without forced induction. Aside from intake and exhaust,
what are my other options? I know where to get cams and pistons,
flywheels, etc. I mentioned an SVX engine swap a LOOONG time ago,
and that's still an option, I think. Any suggestions?
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/3PCXaC/PfREAA ... /XoTolB/TM
Risk Free!
subman2001nz
N/A Power
Alcohol & Water injection, 62mm throttle body, flow your exhaust
ports on the block and match with the manifold, slightly larger
injectors.
I wouldn't worry too much about pistons at this stage, but you will
get great performance from a cam.
boost
Risk Free!
injectors.
boost
Risk Free!
georgerbyrne
N/A Power
I have had my cams reground to a stage 3 Road/Race spec, and that
along with custom exhaust, ported and polished heads, higher
compression, modified throttle body, pod filter with cold air intake,
and a lightened flywheel with an uprated WRX clutch have made my
Naturally Aspirated liberty move alot better!
Getting some new 8mm leads this week too.
However, after all of this, i don't think it has anywhere near enough
power, and so i will be bolting a rather large turbo and front-mount
cooler on later in the year!
George, Australia.
--- In BC-BFLegacyWorks@y..., "subman2001nz" <daniel.wilson@d...>
> injectors.
> boost
exhaust,
ago,
Risk Free!
George, Australia.
> injectors.
> boost
exhaust,
ago,
Risk Free!
milehial2000
N/A Power
We have done one SVX into Legacy conversion and it is difficult,
expensive and has a few drawbacks like jacking up the engine to change
plugs and being hard to work on in general.
AL(CO)
boost
Risk Free!
AL(CO)
boost
Risk Free!
Sam & Beth Barrett
N/A Power
What was the output like?
-----Original Message-----
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Monday, June 17, 2002 7:28 PM
Subject: [BC-BFLegacyWorks] Re: N/A Power
AL(CO)
boost
Risk Free!
AL(CO)
boost
Risk Free!
milehial2000
N/A Power
Very impressive as we had a supercharger from Mazda Millenia mounted
to the engine. The drawback here was that the Legacy didn't have the
sound deadening that the Mazda had and you could hear it coming a long
ways away. We eventually took the supercharger off because of the
sound problems and SC control troubles and the car really was
pretty quick even without the SC. I have a few pictures around and the
last time I talked to the owner he was thinking of selling it if
anyone is interested. It is a wagon in good condition.
AL(CO)
--- In BC-BFLegacyWorks@y..., "Sam & Beth Barrett" <LEVATHIAN@s...>
> From: milehial2000 [mailto:acroxford@h...]
> To: BC-BFLegacyWorks@y...
change
> AL(CO)
> boost
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Risk Free!
AL(CO)
change
> AL(CO)
> boost
Risk Free!
subman2001nz
N/A Power
Alcohol & Water injection will give you a huge boost, especially in
top end power. I had a group A crank shaft & uprated conrod bolts
balanced and blue printed and that also made a huge difference
Plus I am in the process of converting my N/A legacy to Turbo.
--- In BC-BFLegacyWorks@y..., "georgerbyrne" <georgerbyrne@y...>
intake,
enough
mount
> George, Australia.
Risk Free!
intake,
enough
mount
> George, Australia.
Risk Free!
georgerbyrne
N/A Power
How much did the Alcohol and water injection set you back, pricewise?
Is it hard to set up?
Are there cheap methods of setting this up?
Thanks, George, Australia.
> intake,
> enough
> mount
> > George, Australia.
Risk Free!
> intake,
> enough
> mount
> > George, Australia.
Risk Free!
Douglas Hancock
N/A Power
I have seen reground cam become nothing. Buy the cams in stead.
Sent: Tuesday, 18 June 2002 11:23 AM
George, Australia.
> injectors.
> boost
exhaust,
ago,
Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service.
George, Australia.
> injectors.
> boost
exhaust,
ago,
georgerbyrne
N/A Power
As in they dissintegrated??
OUCH! Mine have been fine, it wasn't a huge grind. And for the next
1000km i didn't rev above 3500rpm!
They are good now, lumpier exhaust note too ;D
George, Australia.
--- In BC-BFLegacyWorks@y..., "Douglas Hancock" <douglashancock@o...>
> From: georgerbyrne [mailto:georgerbyrne@y...]
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
Risk Free!
George, Australia.
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
Risk Free!
georgerbyrne
N/A Power
George, Australia.
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
Risk Free!
George, Australia.
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
Risk Free!
georgerbyrne
N/A Power
George, Australia.
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
Risk Free!
George, Australia.
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
Risk Free!
Douglas Hancock
N/A Power
Yeh I read a mag article. It was in Zoom so I should be able to find it.
Sent: Wednesday, 19 June 2002 9:32 PM
George, Australia.
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
George, Australia.
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
subman2001nz
N/A Power
Cheap, all you need is a water washer bottle with pump. Cooper pipe
to run around header pipes to heat water & alcohol, an injector from
a wreckers yard, wire the injector to say injector 1 on your car. Get
a microswitch to switch the injector on at say full throttle.
pricewise?
in
that
> > intake,
my
> > enough
> > mount
> > > George, Australia.
Risk Free!
pricewise?
in
that
> > intake,
my
> > enough
> > mount
> > > George, Australia.
Risk Free!
subman2001nz
N/A Power
We have a company in NZ that builds up cams for about $250, because
they are built up you don't need to change shims or anything else in
the heads. He does this professionally for race teams all around the
world.
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
Risk Free!
world.
intake,
enough
> George, Australia.
> > injectors.
will
> > boost
> exhaust,
pistons,
> ago,
> zZz
Risk Free!
