Anyone ever had a problem with smelling exhaust inside the car? since my car has been done this has been a bit of a problem...ok pretty big problem lol.Not enough to make me feel ill (yet) but pretty annoying.This is definately exhaust smell,like breathing from the tailpipe distinct.I cant tell if its drafting in the windows or maybe leaking in through the trunk seals,seems to happen no matter how i have the windows unless they are all closed....any ideas??
Btw this is happening at most speeds.
Fumes in cabin!
Fumes in cabin!
That's a big deal because the effects of carbon monoxide are cumulative.
Check for exhaust leaks. Try running the engine and covering the tailpipe with a damp rag. If there are no leaks the engine will just stall out. But, if there are, the exhaust should start coming out of the leak or leaks.
Yeah, that's some bad stuff. I don't know how long it takes for your system to clear it, but like Vikash said, it builds up. You say it doesn't smell when the windows are closed? It wouldn't be your trunk seals, then. Strange to think you could pull air inside from underneath at speed. My guess is it will be towards the front.
My 3" TBE was leaking at the bottom of the downpipe at the joint. Thick gaskets didn't help. Had to put some high temp rv sealant on there to seal it up. Of course, the leak was on the TOP side so couldn't tell by looking, but a hand around there was a dead give away.
'11 WRX Limited
'94 TW | R.I.P.
Make sure you check the firewall for any missing plugs. Especially if you took the AC out or if you don't have one. The seal for the Evaporator lines is right behind the downpipe. It can suck a lot of fumes in from there.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
06 ZZR600
Same thing for me. when swapping out my header I had the downpipe off and noticed that the entire gasket was intact except for a 1/2 inch missing piece at the very top. I didn't hear a differenct or notice anything but my girlfriend was getting headaches in the car.BSOD2600 wrote:My 3" TBE was leaking at the bottom of the downpipe at the joint. Thick gaskets didn't help. Had to put some high temp rv sealant on there to seal it up. Of course, the leak was on the TOP side so couldn't tell by looking, but a hand around there was a dead give away.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Check the manifold, up-pipe, turbo, & downpipe. The leak is most likely in the engine bay.
Well i found not only a leak at the down pipe flange,due to a crown in the flange itself but also an unplugged hole in the firewall also as suggested.Much better now lol,still have to seal another hole where all the additional wiring and crap goes through but no biggie.
so for anyone reading this thread wondering whats up with exhaust smell in their car - CHECK THE OBVIOUS SHIT BEFORE POSTING STUPID QUESTIONS ON-LINE!!!
