I am having problem with my idle speed, much like Josh was. When I
first start the car it has trouble finding a steady idle, jumping
back and forth from about 1000 to below 500 RPM. After a couple
seconds it evens out at around 800 RPM and it begins its slow
increase. After about 1 or 2 minutes of running (after it has warmed
up a little) it is idling at 1300 or 1400 RPM, sometimes even 1500.
But the really strange thing is that if I pump the brakes a couple
times, the idle initially raises up about 200 RPM, then it drops back
down to the correct idle level(about 700)! It stays at the correct
level for a couple seconds then it jumps back up to 1400 RPM. Has
anybody seen this before??
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/3PCXaC/PfREAA ... /XoTolB/TM
high idle
legacycentral
high idle
Sounds like a vacuum leak of some sort, as pumping the brakes would
use some of the vacuum created by the engine.
warmed
back
Risk Free!
warmed
back
Risk Free!
Josh Colombo
high idle
Yeah.....I'd sorta concur with what dave said. Sounds like a vacuum leak or some other vacuum issue.
I'd start there first.......you didn't do anything to your TB did you?
-----Original Message-----
Sent: Wed 6/19/2002 1:19 PM
Cc:
Subject: [BC-BFLegacyWorks] high idle
Risk Free!
Cc:
Risk Free!
limonoah
high idle
No, i didn't do anything to my TB. If I had a vaccum leak, would I
see abnormal readings on my boost/vaccum gauge? I get consistant
readings of 20(in hg) at idle.
you?
> From: limonoah [mailto:limonoah@h...]
> To: BC-BFLegacyWorks@y...
> Cc:
When I
jumping
couple
warmed
1500.
couple
drops back
correct
Has
Risk Free!
you?
> Cc:
When I
jumping
couple
warmed
1500.
couple
drops back
correct
Has
Risk Free!
Josh Colombo
high idle
try pullin codes.....maybe you got a sensor out of whack.
Also could try resettting the ECU.
Sent: Thu 6/20/2002 2:31 PM
Cc:
Subject: [BC-BFLegacyWorks] Re: high idle
you?
> Cc:
When I
jumping
couple
warmed
1500.
couple
drops back
correct
Has
Risk Free!
Cc:
you?
> Cc:
When I
jumping
couple
warmed
1500.
couple
drops back
correct
Has
Risk Free!
limonoah
high idle
I get a o2 sensor error code. I've known my o2 sensor is bad because
my car is running rich...so rich that carbon spits out the exhaust
sometimes. My AF meter says I am running rich at idle and lean while
driving. Could the o2 sensor cause a high idle?
thanks, NOah
> Cc:
would I
consistant
a
TB did
> you?
> > Cc:
Josh was.
> When I
idle,
> jumping
After a
> couple
its slow
(after it has
> warmed
sometimes even
> 1500.
brakes a
> couple
then it
> drops back
at the
> correct
1400 RPM.
> Has
Risk Free!
thanks, NOah
> Cc:
would I
consistant
a
TB did
> you?
> > Cc:
Josh was.
> When I
idle,
> jumping
After a
> couple
its slow
(after it has
> warmed
sometimes even
> 1500.
brakes a
> couple
then it
> drops back
at the
> correct
1400 RPM.
> Has
Risk Free!
Josh Colombo
high idle
It's possible.....if you are getting a code for it, and you have cleared the codes and it continues to come back, I would definitely replace it and go from there. Who knows what problems or other issues are there due to the bad O2 sensor.
Sent: Thu 6/20/2002 2:56 PM
Cc:
thanks, NOah
> Cc:
would I
consistant
a
TB did
> you?
> > Cc:
Josh was.
> When I
idle,
> jumping
After a
> couple
its slow
(after it has
> warmed
sometimes even
> 1500.
brakes a
> couple
then it
> drops back
at the
> correct
1400 RPM.
> Has
Risk Free!
Cc:
thanks, NOah
> Cc:
would I
consistant
a
TB did
> you?
> > Cc:
Josh was.
> When I
idle,
> jumping
After a
> couple
its slow
(after it has
> warmed
sometimes even
> 1500.
brakes a
> couple
then it
> drops back
at the
> correct
1400 RPM.
> Has
Risk Free!
