New valve covers
All my paint fell off the alluminum after a year. I neglected to use an etching primer like I should have.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
I used an etching primer and still had the same problem. Same brand paint, too. Intake manifold seems better, but I haven't installed it yet. I wonder if aluminum absorbs oil to some extent and after 15 years or so, requires soaking in degreaser for an extended period first. I know the paint is good as I've seen it on other things, so it must be something I did wrong.
Some aluminum alloys can definitely absorb oil. I know I have some aluminum cookware that is now yellow because of oil laden with turmeric. Out of curiosity I took a Dremel to it and found I had to grind a fair bit of material away before it was aluminum-colored again.
