ej22e piston sizes
subbieedude!
ej22e piston sizes
Post by subbieedude! »
does anyone know if running a B size piston instead of an A size piston will make a difference? the number are .0004 of a difference
thanks
/// life begins at 20 pounds of boost
tturnpaw
Post by tturnpaw »
four hundred thousandths is not going to make a difference, no. Consider ten thousandths (.010) is the thickness of your fingernail compared to that.
subbieedude!
okay thats what i thought aha thanks for your input
gijonas
Post by gijonas »
That would be 4 ten thousanths actually.
subbieedude!
aha thanks i had no idea how to read, i just know its a really small amount
tturnpaw
Post by tturnpaw »
Actually the correct amount would be 40 hundred thousandths. They are not singular terms. Now that i look at it when im not tired. As soon as it breaches ten thousandths its two digits.
gijonas
Post by gijonas »
Ok how about 400,000 billionths ?
