kimokalihi's 91 SS EJ20 Swap
SLODRIVE
Post by SLODRIVE »
1/4" aluminum plate + 2.5" holesaw + drill bit for bolt holes + Sawzall + old gasket (to trace pattern) = TB spacer! It's not nearly as hard as you think.
http://www.slodriveracing.com
-And more!
But you'd need a drill press right? I don't have the hole saw bit, where do you get one that will cut through aluminum? I have a wood hole saw kit but there's no way it'll withstand aluminum.
Do you use gaskets with that?
SLODRIVE
Post by SLODRIVE »
kimokalihi wrote:But you'd need a drill press right? I don't have the hole saw bit, where do you get one that will cut through aluminum? I have a wood hole saw kit but there's no way it'll withstand aluminum.
I used a drill press (since I have one), but it's not absolutely necessary. You'll be able to make a straight enough center hole if you're careful with a hand drill, and you should be cleaning up the hole with a grinder/Dremel anyway. The mounting holes I drilled on the large size so I wouldn't have any issues. I just used a decent Home Depot hole saw (it says Lenox on the saw blade) and it cut through the aluminum pretty easily.
And yes, you need a gasket on each side of the spacer.
-And more!
They still make that swaybar? I NEED one.
$221 shipped I believe from never enough auto accessories.
Here's the link, shipped in less than a week I think. They drop ship from australia direct from whiteline so you don't have to pay extra to have it shipped to them first and then out to you. Shipping is free, or at least it was a couple months ago when I ordered mine.
http://www.neverenoughauto.com/index.ph ... t_id=10936
I compared the thottle bodies today. It does fit upside down. The TPS are not interchangeable I believe and in order to get it to fit you need to get longer vacuum hoses for the IAC and purge solenoid and it interferes with the pipe that runs across the top of the manifold, I think from the IAC to the intake tube.
I'll get pictures up when I get home from work in the morning.
Here's a comparison of the EJ22T manifold and the EJ20G manifold. The EJ20G has the IAC on the left of the throttle body in these pictures and the throttle cable thingy is on the wrong side.
The EJ20G TB is the one with the tape on it.
EJ20G
EJ22T
Here you can see there's a large difference in length of the throttle body inlets.
I bolted the EJ22T up to the EJ20G manifold here upside down to see if it would fit and it does for the most part. But this is where I found out why you need the spacer. The TPS mount does not clear the manifold.
This is why I don't think you can swap TPS's. One is straight and one is offset...a lot. So I would imagine that would make it impossible to swap them.
Here's the two hoses that need to be longer to go to the top of the throttle body if I were to mount the EJ22T upside down.
Here's the pipe that doesn't clear those two hose fittings.
I'll finish editing this later. I can't keep my damn eyes open. I keep falling asleep sitting here trying to type.
Got my heat wrap today. Really quick shipment, I think that was only 2 days. 3 at the max.
How do these stainless ties work? Do you just pull them tight and smash them with a hammer or something?
dropdfocus
Post by dropdfocus »
Simply pull them tight. You can fold back the remaining amount so it creates a kink & it can't pull back through easily.
I may end up pulling off my down pipe and up pipe & wrapping them. Should reduce under hood temps fairly well. I've heard wrapping the hot side of the turbo is a good idea as well.
Jason
Looking at the turbo and this wrap I don't see how you wrap the actual turbo itself. I gotta see pictures of this.
SLODRIVE
Post by SLODRIVE »
I'll try to post a pic of how I wrapped my turbo this weekend.
-And more!
Are you talking about this kind of turbo wrap? Not the stuff I bought for the pipes?
Image[/quote]
dropdfocus
Yes, the foil/nomex blanket wrap.
Jason
SLODRIVE
Post by SLODRIVE »
^^^ That's much nicer than what I did, LOL. I just used some of the same tape I ordered for the downpipe. It doesn't cover the whole thing, but it still helps keep the temps down somewhat:
-And more!
Is there any way you can prevent the bolts and nuts on the exhaust and turbo from rusting like that?
SLODRIVE
Post by SLODRIVE »
kimokalihi wrote:Is there any way you can prevent the bolts and nuts on the exhaust and turbo from rusting like that?
Getting *new* zinc-plated harware (or stainless if you want to blow $$$) will go a long ways. Most good hardware stores carry what you need.
-And more!
PhyrraM
Post by PhyrraM »
It's hard, but I use a Super-hi temp Nevr-Seez. Seems to work, but it seems my downpipe is off once a year. So, it gets refreshed often.
The zinc coating will get baked off over time. It doesn't last. SS is probably the only way to keep it off for sure.
Stainless is decent, but the threads like to gal up over time if you have it on and off a lot. A high carbon plain steel has worked the best as of late. Like 12.x metric allen bolts, the black ones. I tried stainless on my turbo inlet flange, but these other ones have kept their form together better, especially on the threads. They will rust though, and I live in Minnesota so the environment is a bit rough.
Got the aluminum today. Cost me a pretty penny to make this throttle spacer. But it looks like I'll be able to make quite a few of them. Either 9 of them or 12 of them depending on the exact size of the spacer. Gotta measure it.
$13.42 Aluminum 12"x12"x1/4"
$15.95 Hole Saw Arbor
$12.95 Hole Saw 2.5"
$45.92 After tax :shock:
Bummer
Hopefully I can make some of these and come up with a price for them to cover the cost and also save some people some money vs spending $46 to make a spacer. I guess they could have bought a smaller piece of aluminum but still the hole saw and arbor was the expensive part.
Maybe $12 shipped or something I dunno.
Today I took the aluminum and hole saw bit to my friends house where he has a drill press. And I found out that hole saw is a piece of shit. It wobbles and cuts a fucked up hole. Really pisses me off. I'm going to take it back.
I did cut the hole out though and drilled the holes for the bolts and was off by a little bit. Also I found out the intake side of the throttle body is smaller than the intercooler side so the hole saw was too big. The hole saw itself fits into the intercooler side barely but it actually bigger than the hole on the other side. Great.
Do you think this hole being this much bigger is going to create problems for me? I don't think I can find the perfect size hole saw and I'm not about to buy another one after seeing how shitty it cut the hole.
I tried calling the machine shops to see how much it would be to cut this out. Should only take a couple minutes to do but I bet they want like $100+ for it. Bastards. Unfortunately I realized it was saturday and about 5pm so they were all closed. Nothing like having setback after setback after setback and it never ends. Stupid project is coming along at a snails pace.
PhyrraM
Post by PhyrraM »
The space should work just fine.
Take a file and knock off any loose aluminum, and run it.
You can shoose to improve it later, after the car is running.
SP-Boxer
Post by SP-Boxer »
I knew those swaybars are still available, but those pre-93 endlinks I can't find...
"I feel Legacy"
