Full STi swap. EJ257 and 6MT!
I have an engine, complete wiring harness, and trans from an 06 STi. This is perfect for converting your tired WRX to STi spec, or great for someone looking to build an RSTi or swap a BC/BJ!
The engine and trans both have 22,000 miles on them. Well maintained, and comes with everything you need.
You get:
Complete longblock assembly
Intake Manifold
Engine harness
Exhaust manifold
Turbo
Intercooler
ECU and wiring harness
Lock cylinder (for the immobilizer)
Keys
Clutch
Slave cylinder
transmission
shift linkage
All you need is a DCCD controller, and a weekend to install it all!
$7000
And for you RSTi/BC/BJ swappers, I can source you a 3.54 rear differential without much issue.
This deal won't be around long, so don't delay!
The best way to reach me is e-mail: Sales@andrewtechautomotive.com
You get:
Intake Manifold
Engine harness
Exhaust manifold
Turbo
Intercooler
Keys
Clutch
Slave cylinder
transmission
shift linkage
$7000
wow, you read my mind.Redlined wrote:Wow! just wow! maybe I can find a buyer for my left testicle so I can afford that!
1998 VW GTi VR6 5MT (SOLD)
If I hadn't have done my motor, I'd probably go this route.
Not for an 06 trannylegacy92ej22t wrote:Don't you need the axles and stuff to do the tranny swap?
The 06 tranny has a 3.90 front diff with 1.1:1 transfer gears. Get a WRX R160, swap the flanges (included), and use the STi driveshaft (included). Bolts right up.
For the front, if they are male axles, they clip right in. If female, just get stubs for the trans, and the axles work right up (same thing Dan did). I might have gotten that backwards (I can't remember if this trans is stubbed or stubless).
Literally, drop in and go!
Phil
