And yes the best solution is 5MT but thats not happening unless I get another SS and its 5MT
power light flashing on startup question
When it flashes the light on startup does it impact the way the tranny shifts at all like a failsafe mode? Honest to god the car will not shift to 2nd if i have been cruising at 40km/h. Stays in 4th gear sometime. Code is duty solenoid c and I have no awd and 0 torque bind. How does it recognize a issue anyway? I can go as far as 1/2 throttle+ no gear change just sitting just under 3000rpms barely going faster. Of course I can just jump on it to get the power light on, but its annoying I should not need to jump on the throttle after making a right turn EVERY time.
Clear the codes and see if that particular code comes back.
