I just got the bolt and sleeve for my shifter and was wondering if I should bolt the shifter in or not.
What I'm really asking is, should I leave the shifter off and install it inside the car once the tranny is in? I thought I read on a thread that it's a bitch trying to get the bolt through the shifter because of limited room inside the car.
Easier to install tranny with shifter or without shifter?
- quasi-mod-o
It's not that easy.
One of the shifter mounts attaches to the transmission, so you can't just install the shifter and bolt up the linkage later.
IMO, it would be better to put as much of the shifter together as possible now, and then just finish it when the trans is installed. It won't get in the way that much.
Yes, putting the forward part of the linkage together will be MUCH easier with the trans out of the car.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
OK, now I'm confused. Which part do I put together before? I have the whole shift linkage connected and installed along with the shifter. Everything is together except I haven't gotten the shift ball into that plastic hole.
What part is the rear mount? The bushing?
I see. I bought a kartboy bushing to replace that. I'll put that in before trying to put the tranny in.
