skoobywrx
Post
by skoobywrx »
still going through all the bugs on this car......day 7 and im still finding new stuff
so the heres a new one, bunch of deteriorated fuel lines:
is there a diagram that shows on where the lines go? do the lines go along the inside or outside of the car?
thanks again.
BSOD2600
Post
by BSOD2600 »
skoobywrx wrote:is there a diagram that shows on where the lines go? .
Have you downloaded the FSM and parts catalog Josh put together? It's in the Stuff you need to know forum.
'11 WRX Limited
'94 TW | R.I.P.
skoobywrx
Post
by skoobywrx »
drop the tank a bit...
and removed the hoses and was suprised to see what i found
yikes, got the parts on order....too bad there not in stock
Post
by ericem »
might explain the rerun fuel system lines under the hood. Thats really messed.
skoobywrx
Post
by skoobywrx »
went to junkyard found some good lines, all fixed and good
