FS: 1993 Subaru Legacy Sport AWD 5MT !!!NEED TO SELL ASAP!!!
Hello LegacyCentralBBS,
I need to find a good home for my 1993 Subaru Legacy Sport AWD 5MT. Complete except for engine. I need to have the Legacy gone by 09/20/2009 or it's going to a junk yard. BEST OFFER. I'm in the Richmond, VA area...anyone interested? Thanks.
Here is some additional information:
1) I’m a huge Subaru fanatic, currently own multiple Subaru’s.
2) I am not the original owner of the Legacy, but it appears that I am the 3rd or 4th. From the CarFax report I purchased when I bought it, the Legacy started out in Maine, then moved to MN and then moved to WI when I purchased it about 4 years ago. I have since moved to VA about 3 years ago. The Legacy has been under a tarp in my driveway and has not been driven since I moved to VA.
3) I purchased the Legacy originally to pull and build the EJ22T for my Impreza. Then I thought about keeping the Legacy as a Rally car. Then I thought about how nice of a Subaru it was and thought about building it into a street/track car. Then I got involved in a frame-up 1977 Datsun 280Z street/track build which is about %99 complete. Now we are moving and my wife is telling me one of my project cars has to go :^)
4) There appears that at some point in the past, the Legacy had a small front-end collision, driver-side wind dam area and the quarter panel by the headlight. Not a huge deal, it looks like someone hit a snow bank. The Legacy drives perfectly fine otherwise. But if you are thinking of a project car, I wanted you to know.
5) The transmission is a 5 speed manual (5MT) and shifts good. The gears are all good but the synchros are on the way out. The transmission will shift without grinding as long as you shift moderately slow. Any sudden shifts and the gears will occasionally grind (usually 1-2 and 2-3).
6) The moonroof glass is good (blue tinted from the factory), the moonroof motor and assembly works perfectly...but the moonroof itself leaks on the front driver side. I think it is just a plugged drain tube, but have not looked into it in detail.
7) The Legacy is Burgundy in color, someone in the past painted the original rims silver, but the tires are almost new.
8) The stereo still works but a previous owner replaced the rear motorized antenna at some point in the past with a manual whip antenna.
9) The fan control in the dash apparently broke at some point in the past and a previous owner wired in a manual switch under the dash. I replaced the under-dash switch with a new switch in the console, so the wiring wasn’t hanging down by your feet.
10) Other than the things listed above, the Legacy is in great shape. The interior will need to be shampooed and cleaned as the Legacy has been in storage for about 3 years. I have preliminarily cleaned the interior already.
11) Pictures can be downloaded from HERE
12) I am also not greedy, you tell me what you think it is worth to you (I think around $300-$400) and when you can come pick it up I will be more than willing to negotiate any and all details.
13) Title is from WI, title is clean (not salvage) and is ready to transfer
Here is the information off the plate in the engine bay:
VIN: JF1BC6733PG603728
Model: BC7DY8Z
Option Code: RM
Trim Code: 320
Engine Type: EJ22TAW3BB
Color Code: 218
Transmission Type: TY752VJ2AA
Also, if anyone is planning on a car build, we also have a used 2002 WRX engine in the shop that needs to be sold. It would make a perfect build engine. If you are interested in the 2002 WRX engine long block, the owner of the garage Brett Bajcsi (bajcsi at zenonline.com) said to make him an offer. The engine needs a new valve on one head, the same head needs some minor repair due to the bent valve, but all of the pistons and cylinders are undamaged. Entire engine is drop-in ready. Brett is motivated to move the engine, so feel free to negotiate price.
Model: BC7DY8Z
Option Code: RM
Trim Code: 320
Color Code: 218
sporkedtospec
RckyMtnLegacy
soobrdad02
is this car sold?
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
the_watts10
is car sold man i live in asheville NC and go quite a bit to the manhiem car auctions if car is not sold please PM me back i had a 94 auto the same color and absolutely love this car so please if car isnt sold let me know!!!!!!!!!!!! thanks justin
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
