Wierd idle...help
SPUMONI_RT
Wierd idle...help
After the car is warmed a little, were the idle drops after start up. I'm not sure of the exact rpm but I think it is around 700rpm maybe it will run at a low idle and jump up for a second every few seconds. It isn't random it has a sequence, it is only when idleing once warm.
SPUMONI_RT
SubiePrice88
Has your check engine light came up? Id check for possible codes and than clear the old and see which ones come back.
Id say clean the MAF, IAC and Throttle Body its worth a shot and pretty cheap.
http://bbs.legacycentral.org/viewtopic. ... sc&start=0
You can do a search for most of this stuff, Im pretty sure its all been answered before.
Good Luck!
Good Luck!
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
