oil pumps?
greg donovan
oil pumps?
Post by greg donovan »
i think the oilpump on my ej18 is on its way out. can i use oil pumps from other ej motors on it?
thanks
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
douglas vincent
Post by douglas vincent »
99.9% sure thats a yes
Post by entirelyturbo »
Basically. I know that EJ18s and early EJ22 NAs use the same pump.
In fact, the pump I rebuilt for my car is off the EJ18 motor I had.
*Formerly DerFahrer*
BSOD2600
Post by BSOD2600 »
Curious, how'd you come to the conclusion the oil pump is going out?
'11 WRX Limited
'94 TW | R.I.P.
For the pump itself to go out, it would be pretty nasty. A Subaru oil pump will keep pumping until the gears ripped themselves apart.
greg donovan
BSOD2600 wrote:Curious, how'd you come to the conclusion the oil pump is going out?
puking oil when i rev it hard for a while. if i drive it casually no leaking.
however, i am now pretty sure the pump is fine but just needs some screws inside tightened up and loctited so that it stops pushing oil past the crank seal.
96 Impreza L sedan
00 Impreza RS sedan
Matt Monson
Post by Matt Monson »
Greg,
That's probably got a 7mm pump on it. You can upgrade it to either a 9mm NA Ej25 pump or a 10mm Ej205 pump. All oil pumps are interchangeable. I run the 10mm on my 2.5RS.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
jaybirde508
Pump case blots
Post by jaybirde508 »
Greg,
That is a very common issue with the ej engine the bolts/screws backing out on the rotor case/backing plate working there way loose due to vibrations & causing a leak from nowhere?
Great job ,you called it!
Jay
