According to this video: http://www.youtube.com/watch?v=197yHCBg ... rofilepage
I gotta take the whole hub off. Well from my experience with the first CV shaft replacement I did, taking the hub off means that springs going to decompress and make getting the hub back on later a nightmare. I got the spring tied up with many loops of steel cord and I hope it will at least stay in place somewhat.
Gonna go rent a tie rod tool (we bent our own using it as a cheater bar during the earlier CV job on dads van) and a wheel bearing press.
I got the axel nut off (cut it in half) and the brake stuff and the nut to the Tie Rod. Once the Tie rod is off I'll take off the strut nuts and then the ball joint nut.
I wish I could take pictures but I don't have any kind of digital camera. I'm that poor.
EDIT: Wooo, the spring only dropped like half a inch. (not 4-5 inches like it did on my dad's van.)I don't know how much my string had to do with that.
Anyway, I run into a little issue: How do I yank the CV shaft out of the transaxel. I pulled straight out on it pretty hard...is there a clip? Or do I need to go eat my wheaties and try again?
Also, they didn't have a wheel bearing tool like on that vid so i'll just have to take the hub and my new bearings to a mechanic.
