The issue I'm having is not that the wiper motor doesn't work, (it does work) but only if you pull on the 'shaft'. Shaft= The threaded shaft that sticks out awaiting the wiper arm.
It has about a quarter inch of in and out play. When it's in, you can hear the motor working, but the shaft isn't spinning. When you pull on it, it then starts working properly. But when I have the arm installed it is down and therefore doesn't work.
Am I missing something? Is there supposed to be that much play in the 'shaft'?
![Image](http://i193.photobucket.com/albums/z295/SKATEDEES/wipermotor.jpg)
