control arm jdm any difference?
yazmo
Post by yazmo »
guy anyone can tell me if control arm if different from turbo model from n/a or awd or fwd? this is jdm control arm supose to be better
its close to where i leave just wanna know if this would fit well on my leg 94 turbo
http://toronto.kijiji.ca/c-ViewAdLargeI ... ageIndex=0
Don't know what those belong to, but they're not from a Legacy. Did you bend a control arm or something?
fishbone79
Post by fishbone79 »
Doesn't it say "supra" right on those things?
Cheers,
morgan
1992 Legacy BF
yazmo
Post by yazmo »
evolutionmovement wrote:Don't know what those belong to, but they're not from a Legacy. Did you bend a control arm or something?
i will confirm this later
Just get an OEM one—they're cheap and they work. You can go to alloy arms, but they cost more and there's the argument that the next big hit might cause damage to the crossmember instead as the alloys are built for strength rather than weight reduction (I have them and they seem tough as hell). I doubt the steel control arms in Japan are any different. It wouldn't make any sense manufacturing-wise and these cars were built pretty smart in that regard. For applications requiring stronger arms, they had the alloy units.
Bdub
Post by Bdub »
Looks like it says Supra on them...as stated above.
I have 00RS control arms, which are the exact same thing as our Legacy. The benefit on using the RS arms are they are newer, and no rust or corrosion. Also, I found mine with all the bushings still intact and in good shape.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
n2x4
Post by n2x4 »
Don't waste your money. You'll benefit more from upgraded bushings. Besides, those are DEFINITELY not for any Subaru I've ever seen.
SUBARUEHS Racing
dscoobydoo
Post by dscoobydoo »
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
