I got my new toy, and now my boost is all screwed up.
There's definitely something wrong under the hood with the way I set
up the vacuum lines. The wiring seesms right, as all sensors are
giving correct readings to the Avc-r, but my problem is my fuel cut
keeps kicking in VERY prematurely. So I turned down boost and duty
settings to their minimum... fuel cut still kicked in. Turned start
duty down all the way as well... fuel cut STILL kicked in. I said
to hell with it, and bypassed the boost control solenoid and ran
directly into the wastegate, AND FUEL CUT STILL KICKED IN!!!!
Now I admit, i'm a friggin' idiot thus far when it comes to
mechanics, and I know some of you are gonna say I should have it
professionally installed, but to me, doing this stuff first hand and
learning as I go means as much to me as having a fast ride. (and
yes, I'm prepared to deal with the consequences of blowing up my
car.
So, can anyone tell me the correct vaccuum line setup for using the
Avc-r in our Legacies? Pictures are worth a thousand words. And
which sensor tells the ECU my current boost pressure? Could I have
a bad sensor?
Thanks everybody,
- mike
P.S.: The A/C is out, I'm cleaning up the condenser, and awaiting my
parts for my rigged A/W intercooler setup... should be fun!
