4POT brake calipers
subaruracer755@cs.com
4POT brake calipers
no the 4 POTs will not fit behind the stock legacy wheels. you will need a set of 15"compmotive rims, the rims off of a 98-99 2.5RS or something bigger like a set of prodrive P-7s
Josh Colombo
4POT brake calipers
you need at least 17's to fit the subie 4-pots under the wheels, or possibly some 16" wheels will work....OEM subie wheels will not fit the 4-pots under them.
Douglas Hancock
4POT brake calipers
You only need 16inch wheels. They came standard from 98 onwards in OZ.
Douglas Hancock
4POT brake calipers
Started about 1000 kms ago. 4000 kms in total since oil change. They got to the stage where they were constant. I put in some engine additive, called Nulon performance Engine Treatment. I have always been worried about engine additives. I gave it a try knowing that this was the last shot before an engine rebuild or replacement. It has totally fixed it for now but how long it will last, I don't know. Its only been in since Saturday so fingers crossed. By the way it is as just like oil but blue. Here is some pics of the bottle. The very last thing I do is rebuild the oil pump at 200,000 kms if it lasts that long.
Regards Doug
Newcastle (Australia)
Regards Doug
