What is the wheel bolt pattern for our Subarus, other than the SVX.
Thanks,
Mark
Wheel bolt Pattern
Kam
Wheel bolt Pattern
From memory it's 5x100 PCD with a center hole 50mm(?? not sure about htis one) and 55 offset
Lee Jergensen
Wheel bolt Pattern
Wheel has 5x100 bolt pattern, but center bore is 56.1
and the offset of stock wheel is 35mm
