No power unlock after lock fix
SPUMONI_RT
Post by SPUMONI_RT »
I recently fixed my door locks because the spring retainer was broke on all of them.
I found a thread on how to fix them by wiring the spring back. I also used dual sided tape to go in between the mechanism and the door to insure there was no rattles.
I don't remember if they worked after I fixed them but they did work before that. And they don't work now.
They unlock when I use the key but not the button.
I was wondering if anyone has any insite
Are you pressing the button far enough to get all the doors to unlock?
tahiti350
Post by tahiti350 »
I put a spring on one that I had that was broken, but hte spring kept it from traveling far enough to trip the switch, swapped it out with a good one from the wrecking yard and walla, everything worked again
'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
SPUMONI_RT
I press it down far enough.
I didn't replace the springs.
I guess I'm going to have to pull it apart and
hope I can see the problem.
-Spumoni-
