so I have the EJ22T stripped down to the block and will split it next weekend so it'll be ready to be bored out. Now i need to think about internals, specifically the pistons and rods. I want to run the wiseco EJ22T hybrid piston b/c i'm gonna be running the EJ25 DOHC heads, now i need to find some rods to go with the pistons, there are K1 h-beam rods for the EJ20/25 and i figured thats what i needed but i'm not 100% sure.
Thanks for any info on rod choices.
Logan.
Engine Building...
Engine Building...
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Any rod designed for either the WRX EJ205/207 or the STI/LGT/FXT EJ257/255 will work.
The common low-buck upgrade is USDM STI EJ257 rods.
ok...how well would the STI rods hold up to 300-350ish hp?
race_to_live
