smog results!!!!! uh oh need help
so after a new purge solenoid, knock sensor, back pain, and beer. I took soobie for the CA smog test and it didnt pass!!! lame but at least the CEL light doesnt come on anymore. I failed the Idle test heres my results can someone gice me some advice on what i should do.
RPM/ MEAS CO2 / MEAS o2 / HC PPM MAX..AVE...MEAS /
696 14.4 0.8 100 17 162
CO(%) MAX...AVE...MEAS/
1.00 0.00 0.31
The ones I failed is the HC (PPM) MAX and MEAS. so any ideas, I know this is alot but I appreciate any feedback
1.00 0.00 0.31
1993 legacy ss "Shela"
Smithcraft
fishbone79
High HC would be indicative of rich running condition... could be several things. However, have you ever replaced the O2 sensor? That would be my bet, all other things being equal (assuming that your plugs are new and at the correct gap, etc). What's your mileage like?
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
Legacy Konig
I would do all the routine maintenance. Also, if the coolant temp sensor is old and not reacting as quickly or properly it could be running rich. If you don't know the age of it, may want to replace it.
Lunatech
Well, let's think...you had codes for knock sensor, purge solenoid sensor, MAF and IAC, CEL is out now and you have occasional crappy idle.
Could be an issue with idle air control. IDK if it would cause you to fail emissions test, but it's a thought.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
NuclearBacon
At idle, you're so close to passing HC! usually bad sparkplugs/wires would give you no good readings on your idle test. i was blowing a 400+ ppm on HC, switched out my spark plugs only, and passed no problem.
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
I was at around 600 PPM HC at idle when I took my test and it was because my car was running too LEAN.
So maybe you should start looking at both ends. Do you by chance have a wideband?
SLODRIVE
The high HC readings indicate some kind of engine miss, as in your rough idle probably has something to do with it. If you were running too rich, your CO numbers would have been much higher, and conversely, CO numbers often read VERY low if you're too lean. As stated by others above, check your IAC as well as your plugs/wires.
http://www.slodriveracing.com
-And more!
-And more!
awdimprezal
ALWAYS rev your car up to 3K and hold it for 5-8 straight minutes before a smog test. Thats what the instructors @ my school always used to say ( when we had smog testing LOL) a HOT cat will make sure its working correctly.
1996 impreza L AWD boosted n/a 2.2. 60 trim T04E turbo, well over 200k miles, 11 psi daily. No management.
