Need to know how to self-check what CE code i am throwing...did the turbo, IC and HKS downpipe wrap up last night (started Wed. night), and car now has a CE light immediately when you start it....seems to run fine though.
My Chiltons book (all I ahe for a car that old!) says that when the key is in the on position, the CE light will pulse the code...and if the self diagnostic plug is still plugged in, the CE light will flicker....mine just stays solid when you put the key into the on position.
Adam
check engine light
Josh Colombo
check engine light
Hey Adam,
Just for future reference.....I've got all that info on my site www.surrealmirage.com/subaru in the notes & tips section. Has all the codes, how to check codes, how to get into d-check mode, and clear the codes. I also have info on how to pull the TCU codes too.
