Thanks for any help you can provide!!!!
Freshen up EJ20G heads with USDM parts?
dropdfocus
Does anyone possibly know if I can use USDM parts to freshen up the EJ20G valvetrain in the heads I have for my future motor build? The heads I have are shimless bucket over valve design if that helps any...
Jason
Most parts should be interchangable with '96 (only'96) Outback/Legacy 2.5 GT EJ25D parts.
IIRC from the EJ20G parts list on Nasioc, everything but the camshafts is the same. Even the valves and (non-STI) HLAs are the same.
dropdfocus
