FS:jecs maf and hitachi maf
i'Ve a jecs maf! need to sell it because i"Ve two off them and just need one you know
was working great when take out of the car!
45$ shipped
also have hitachi maf for 35 shipped
45$ shipped
impreza 95, ej22t engine swap!
What's it look like? Do you have a picture? I'm going to be putting my intake together soon hopefully but I need the whole tube that the MAF atatches to/is part of.
Also, is it the same connector as the regular US hitachi MAF and is it compatible with the USDM ECU?
This is the setup I'm going for exactly except I'd like to either build a box completely around the filter that sucks air directly from the fender or run the intake tube all the way into the fender and have the filter out there.
So I need the JECS MAF along with the metal tube or plastic, doesn't matter that it goes on.
If you have this, I'll buy it from you.
I'm not sure what you mean by it probably won't fit the EJ22T? I have an EJ20G and I'm going to run that same exact silicone intake and MAF silicone tube.
What part won't fit?
I'm still a bit confused. Do you have the tube that the MAF is attached to? Just the short little 4" or so long tube. I'm not sure if it's one piece with the MAF integrated into it or if they can be seperated but I need the tube that the MAF is on along with the JECs MAF. I don't want the hitachi one, I've got one of those already.
Do you have paypal?
Do you have paypal?
Funds are short right now and I won't need it for quite some time so I'm gonna pass on this one. Sorry.
