knock sensor
vtxrider
knock sensor
Post by vtxrider »
cel code 22 knock sensor on 94 turbo 5speed. Have replaced the knock sensor with used ones and then finally with a new one. Have put in a ecu from a 92 turbo 5 speed and still have the cel with a 22.
SubiePrice88
Post by SubiePrice88 »
Have you cleared the codes?
Search and you will find! I just dont have alot of time right now to explain.
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
vtxrider
Post by vtxrider »
Yes I have cleared the codes many times.
My bet is bad knock sensor wire. Might need to splice the wire back in order for it to work.
vtxrider
Post by vtxrider »
It could be wiring seeing that the engine compartment of a turbo gets hot. This is 16 years old and the wiring is brittle . It has been spliced but only back to the shielded cable. Can the shielded cable be take off farther back with out hurting it and the wire splice farther back?
The wire is a solid core wire. You'll probably be better off just running a new wire. You'll be fighting the stock one I think...
Dynamic Entry
Post by Dynamic Entry »
Dumb question alert:
Does having a code 22 you can not get rid of NECESSARILY mean that the knock sensor is not doing it's job?
To clarify my meaning, consider that some times the component a sensor is monitoring can be in good order, and the only problem present is the MONITORING of that component, not the component itself. For instance, a coolant sensor float could break thus eliminating the ability to properly monitor coolant level and yet the coolant level could be fine.
So could a bad knock wire simply disallow the system to know if the knock sensor is working, or will it necessarily keep the knock sensor from working.
Oof.
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
If the signal to the knock sensor is not there, the ECU goes into limp mode since it is not receiving that information.
If it's receiving the information, everything's working and you don't have a code.
I guess I may not understand the question....
tahiti350
Post by tahiti350 »
If the signal form the sensor is weak or no existant then the computer reads that as out of tolerance and sets the code. even when there is no knock there is still continuity on the wire that the computer should be reading.
So, to answer your question yes the wire can and does cuase the CEL for a knock code, even if there is no knock and a good sensor.
Other sensors and systems may or may not provide the same feedback, such as a failing MAF...
'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
Dynamic Entry
I think you guys answered my question, which to rephrase would be put:
Can a motor without problematic knock and a working knock sensor still run badly because of a poor knock sensor cable? (as opposed to merely showing the CEL without any adverse affect to the motors power output)
And since you said the computer will go into limp mode without signal, the answer seems to be yes.
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
You are correct. :)
Dynamic Entry
but, if the cable IS problematic, then the CEL should light up ya?
I have a code 22 stored in my computer, that doesn't clear, but I never have a CEL...
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
Not necessarily.....it should show a CEL, but the ECU's sometimes don't.
magicmike
Post by magicmike »
if the cable is somehow shorting to ground like at the bracket where the connector mounts to the back of the motor then perhaps.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
BSOD2600
Post by BSOD2600 »
Run through the FSM knock sensor diagnostics. If all checks out, then the should be ok.
'11 WRX Limited
'94 TW | R.I.P.
Dynamic Entry
my multimeter is effed, this is a good reason to get a new one
thanks for the replies guys, I need to get on this sometime. too bad I'm Cpt. Lazyass McPants
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
magicmike
Post by magicmike »
They get too technical with this garbage. The knock sensor is just a shock sensor basically.
Picture two cylinders with a very small gap between them. The inner cylinder is chassis ground (you can see it when you bolt the sensor to the block). That should be clean.
The outer cylinder is what the wire is connected to that goes to the ECU. The outer cylinder "floats" very close the inner cylinder.
If the engone shakes violently the two cylinders touch thus making the sensor wire go to ground and triggering the code.
got it?
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Dynamic Entry
good to know the theory behind it, I always like to understand the why, so thanks
but really my main concern is making my legacy less tempermental and more consistent, so, I'll check the function of the sensor/wire and see if it needs attention
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
93Leg-c
Re: knock sensor
Post by 93Leg-c »
vtxrider wrote:cel code 22 knock sensor on 94 turbo 5speed. Have replaced the knock sensor with used ones and then finally with a new one. Have put in a ecu from a 92 turbo 5 speed and still have the cel with a 22.
You may also want to check the angle that the knock sensor is installed.
Some years ago I had a pinging and knocking problem with a new knock sensor. When I checked the FSM instructions, it says to install the knock sensor with the wire pointing at a 45 degree angle (if the passenger compartment direction is 12:00 and the direction toward the front of the car is the 6:00 position, the knock sensor wire should be pointing towards the 10:30 position).
That ended my pinging and knocking episodes along with the code 22 and CEL.
I don't know the technical reason why it should be installed that way but it solved the issue.
'94 TW
BSOD2600
Re: knock sensor
Post by BSOD2600 »
93Leg-c wrote:You may also want to check the angle that the knock sensor is installed.
I've heard of this too, but never actually found a FSM scan which contained these instructions. Do you have a link to it per chance?
'11 WRX Limited
'94 TW | R.I.P.
93Leg-c
Re: knock sensor
Post by 93Leg-c »
No, sorry, I don't have a link to it. But I'll see if I can find it online somewhere. And my scanner broke some time ago...
'94 TW
log1call
Post by log1call »
The knock sensor is concentric and it doesn't make any difference to it's operation which way the wire comes out other than it needs to be secure so the wire doesn't shake around and, not be too tight.
Also, the sensor works on a piezo principle and does not earth or make a connection. It generates a small voltage.
If the sensor is overtightened to the block it can cause too much signal which can trigger a trouble code.
Bad fuel, heads that have been planned too many times, over-heating, oil burning, mechanical noises... they can all trigger knock detection and if the ecu can not stop the knock after it has retarded the timing as far as it's allowed(which is about twelve degrees.. varies a bit), then the knock sensor code gets set.
martimus919
Post by martimus919 »
Fixed it! when I tried soldering the bad wire before I had real crappy solder and gun, this time i spent more time on it and got the proper solder.
